Old 09-03-2013, 08:18 PM
shawnu's Avatar
shawnu shawnu is offline
Vehicle: 2012 Ram
Rep:517
Thanks guys!! Ive always heard good stuff about wix filters.
I guess ill stick with M1 but use a wix filter from now on.
New audio build in progress
Old 09-03-2013, 11:45 PM
Hermes1 Hermes1 is offline
Vehicle: A Truck
Rep:2549
You won't be disappointed Wix filters will do right by your truck. Also as I recall there are quite a few on this forum using Mobil 1 and Wix filters, so you will be in good company.
Old 09-04-2013, 04:30 PM
kkreit01 kkreit01 is offline
Vehicle: 2012 Ram CC 4x4
Trim Level: Outdoorsman
Color: Sagebrush
Rep:87
kkreit01 will become famous soon enough
The "look" or "shade" of the oil means very little. Follow your manual, check your level, and no worries. If you are really concerned, send it in for a UOA.
Old 09-10-2013, 05:04 AM
ValleyRacer ValleyRacer is offline
Vehicle: 2013 Ram RT
Trim Level: RT
Color: Steel Blue Metallic
Rep:136
ValleyRacer will become famous soon enoughValleyRacer will become famous soon enough
Default Good oil choice, crappy filter, oil darkens
Originally Posted by shawnu View Post
Just like the title says, i have 10,4xx miles on my express and I changed my air filter yesterday because it was looking pretty nasty and checked my oil while i was under there, i use mobil 1 full synthetic with a mopar filter and my oil is already looking dark.
I think it should be looking fairly new but its not. Im planning on going on a 1500ish mile trip in 2 weeks and will be changing the oil and give mobil 1 another try then if i get the same results i might give pennzoil platinum a try.
Any idea why my oil is already dirty?
Firstly - good choice in motor oil. Secondly - MOPAR doesn't make oil filters. You have a re-branded, repainted oil filter from some filter maker with unspecified filtration media.
Thirdly - how long has the Mobil 1 been in? You should have checked your oil occasionally before 10K miles.
Was the oil low at all?
Old 09-10-2013, 09:02 AM
shawnu's Avatar
Vehicle: 2012 Ram
Rep:517
This is oil from my second oil change, its only been 3,8xx miles.
i could never go that long without an oil change. Lol.
Old 09-10-2013, 09:36 AM
Gantman's Avatar
Gantman Gantman is offline
Trim Level: Tradesman 4x4
Rep:974
Come to think about it, my oil changes always got done around 3000 miles when I lived in the desert or hot temp states. The one variable to frequency of oil changes always falls on normal to abnormal operating conditions as stated in practically every owners manual.
Old 09-13-2013, 09:30 PM
05ram's Avatar
05ram 05ram is offline
Vehicle: 2004 Dodge Ram SRT10 RC 6spd
Trim Level: SRT10 RC
Color: Brilliant black
Rep:145
05ram will become famous soon enough05ram will become famous soon enough
With a good oil like Mobile1 use a good extended mileage filter, Mobile1 or the new BOSCH Distance plus. I use Mobile1 15-50 in my SRT10 but DO use the special white Mopar Viper filter, it's the only on that flows enough for these V10's, holds 75psi at idle, hot!!!!!! The filter needs to keep up with the oil flow in my case.....
Traded in[SIGPIC]2004 SRT10 RC in black, with 500+HP, B&G Stage2 PCM, K&N drop in, JMB Catless mids, JTSVP Gen1 shifter, all synthetic fluids, lots of underhood billet with a Snakeskin radiator cover from JTSHydro, LED tails, BedRug, colormatched tonneau!!!!!!!! Upgraded!!!!!!!!
