Old 09-02-2013, 05:21 PM
89powerram's Avatar
89powerram 89powerram is offline
Vehicle: 2004 dodge ram 1500 hemi 4x4
Trim Level: Slt
89powerram is on a distinguished road
Default P0700 code after tacking out in gear position 1
So I put my truck in 1 to see how fast I could go before tacking out then after that when I went to take off it was sluggish and the check engine light come on I deleted the code and it runs fine now so what happend
-IF YOU CANT DODGE IT RAM IT!!!!
Old 09-02-2013, 05:25 PM
Gantman's Avatar
Gantman Gantman is offline
Trim Level: Tradesman 4x4
Rep:974
Just a stab in the dark? But maybe fuel cut-off then into limp mode? Hence sluggish until ignition off/on reset? Just a guess.
Old 09-03-2013, 08:01 AM
TransEngineer TransEngineer is offline
Vehicle: N/A
Rep:358
TransEngineer is just really niceTransEngineer is just really niceTransEngineer is just really niceTransEngineer is just really nice
P0700 (in the ECM) means there is some other code set in the TCM (which is what actually caused your limp-in condition). You'd need to get that code in order to see what actually happened.
If it's running OK now, I wouldn't worry a whole lot about it. Maybe a momentary sensor problem or something. If you were in full limp-in (4th gear only), that was probably in response to some electrical issue (bad wiring connection somewhere, bad sensor reading, etc.).
Old 09-04-2013, 06:05 AM
89powerram's Avatar
Trim Level: Slt
Could it be my battery connectors they look pretty rough
Old 09-04-2013, 07:26 AM
Vehicle: N/A
Rep:358
Yes, low battery voltage (or bad connections) could cause trans limp-in. In that case, you should find a P0562 (Battery Voltage Low) fault code in the TCM, I believe.
