Old 09-14-2013, 08:17 PM
johnny248 johnny248 is offline
Vehicle: 2011 Ram
johnny248 is on a distinguished road
-Expensivetoys
I've never been a fan of lowering t-stats on an stock engine unless it really needs it for some reason. Although engineers tend to do things that aren't always necessary, something like cooling and operating temp must be set up that way for a reason.
That being said, would there be any issue with a 190deg t-stat? somewhere in between the 180-203 options. Again, I don't know if there would be any reason on an '11 style truck. A lot of guys SWEAR buy their 180 stats for better performance and better fuel economy...
Old 01-28-2014, 04:58 PM
planetbrian planetbrian is offline
Vehicle: 2014
planetbrian is on a distinguished road
Originally Posted by johnny248 View Post
-Expensivetoys
I too would like to know if there is a 190 or 192 degree thermostat that will fit in a 2013-2014 5.7 hemi that will still make the computer system act correctly as the engineers designed it to.
Old 01-28-2014, 06:36 PM
USAF Long's Avatar
USAF Long USAF Long is offline
Vehicle: 2013 Ram 1500 RCSB
Rep:69
USAF Long will become famous soon enough
Send a message via AIM to USAF Long
Originally Posted by ncgatorram View Post
I have a BD tuner and monitor temps with it ... I don't plan to change any parameters after install. I am running it with MDS enabled.
Any update on your mileage situation?
-Scott Long-
2013 Ram Express RCSB: 5% tint, de-badged doors, muffler delete y-pipe, K&N panel filter.
Best Run: 14.60@96mph with 2.4 60' at Kil-Kare Raceway in Ohio
Old 01-29-2014, 08:27 AM
Nutshell's Avatar
Nutshell Nutshell is offline
Vehicle: 2015 Ram Crew Cab 4x4
Nutshell is on a distinguished road
I've done this mod on several vehicles...don't think it made a difference.
2015 - Brilliant Black, Line-X, 3.92's with LSD, 4X4, Bilstein 5100's, ARE cap
Old 02-07-2014, 12:10 AM
Lincoln5.7's Avatar
Lincoln5.7 Lincoln5.7 is offline
Vehicle: 2008 Dodge Ram 1500
Trim Level: SLT Big Horn
Rep:26
Lincoln5.7 is on a distinguished road
I was thinking about getting a 180 tstat for my truck but I was wondering how many mods would you need for it to help? I have a CAI, Tunner, 85 mm TB, flowmaster exhaust.
Bullydog GT Programmer Tuner, Flowmaster 40 series, 2 Polk MM1040's, 85mm Throttle body, Volant Powercore CAI, McGaughy 2in drop shackles, 22x10 srt10 rims, CCFL Halos, Belltech Street Performance Shocks.
Soon to come: 4.56's and Pacesetter LT with Y-pipe, Cat delete.
Old 02-07-2014, 03:14 PM
RogerRamJet's Avatar
I do it because I can!
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
There are many, many hours of reading available on the 180 degree T-Stat pro and con discussions. Dive in and have a look.
Old 02-07-2014, 03:34 PM
cclark666's Avatar
cclark666 cclark666 is offline
Vehicle: 2012 RAM 1500
cclark666 is on a distinguished road
ONLY reason a 180* stat is being used is to reduce block temperate, thus helping to reduce knock after installing high flow air filter, exhaust, tuner, etc.
Spintech Exhaust. Bilstein 1500's. aFe Stage 2 Intake. JBA Headers. Diablosport Trinity (with HemiFever tune). Catch Can. 190° tStat. Moe's 85mm Throttle Body.
Old 02-07-2014, 05:08 PM
Buellrider's Avatar
Buellrider Buellrider is offline
Vehicle: 2012 ram 1500 R/T
Trim Level: R/t
Color: Wht
Rep:145
Buellrider will become famous soon enoughBuellrider will become famous soon enough
Cooler engine cooler cylinder temp less chance of detonation also the computer in theory ( not sure every computer controlled car) reading the cooler cyl temps will not pull out as much timing ='s more power thru the entire power curve. At the same time cooler engine temp will cause a richer fuel mixture and the computer on some again I'm not Sure Every... Will richen the fuel mixture even more trying to get it to operating temp. Which is perfect for bolt on modded trucks adding cold air, exhaust, tuners, throttle body, headers. If your only mod is a cold air your not gonna see much... If you have all the above it'll make quite a difference and also make it run safer with less chance of detonation because it's running fatter. Back in the old mustang days my blown 93 Cobra had a 160 but that old computer was easy to trick that was before tuners came along. Thermostats are super cheap and easy throw one in and butt dyno!! The cool thing now is having a Trinity T1000 and being able to monitor knock and timing and seeing gains or losses.... I highly recommend the T1000 the drivability of my truck alone was worth the price.
2012 R/T
Old 08-08-2014, 10:19 PM
ncgatorram's Avatar
ncgatorram ncgatorram is offline
Vehicle: 2011 Ram 1500
Trim Level: Sport 4x4
Rep:69
ncgatorram will become famous soon enough
I have measured mileage with this for almost a year now. I do mostly around town driving with a good bit of stop and go. Also have a heavy foot . Avg MPG is 14.0 ... I was averaging about 14.5 prior but I was doing more hwy driving a year ago and I have bigger tires.
Old 08-09-2014, 05:56 PM
HammerHead's Avatar
HammerHead HammerHead is offline
Vehicle: 2013 RCSB
Color: SILVER
Rep:20
HammerHead is on a distinguished road
I was on the fence about this mod but I figured I would try it and see and if I dident like it I would just put the stock tstat back in. It dropped right in and I like the way the truck runs. Tested it with some hard driving and max coolant temp hit 196 and oil got too 206 degrees. Normal operating temp for the coolant is 185 and the temp depends on how long I run the truck. Usually in the 190's. the biggest thing I noticed is the oil temp takes longer to get into the 190's.
Geared-Tuned 14.0@96
Proud member of the 4 second club...
