2004 1500 cruise problem - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 09-02-2013, 08:27 PM
Dslove Dslove is offline
Vehicle: 2004 1500 SLT
Color: Deep Molten Red
Dslove is on a distinguished road
Default 2004 1500 cruise problem
I have a 1500 with the 4.7 magnum. My cruise control will illuminate the light on the dash. When I press set, nothing happens. Sometimes, if I press accel the rpms will go up, but the cruise control will not hold. If I turn off the cruise at speeds over 25 mph, it will not turn back on. To activate the light on the dash, I would have to turn off the truck and start it again. My speed sensor on the transmission is new. My servo holds vacuum. My hoses are all good too. I am at a loss here.
Old 09-02-2013, 11:03 PM
RogerRamJet's Avatar
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
Do you have a scan tool? If so, you can check to see if the computer is recognizing the request for CC. If you don't have a scan tool, it sounds like you've already checked everything that you check. I'm thinking it's computer or switch related.
Old 09-03-2013, 02:31 PM
Default Thank you
I do not have the right scan tool. I may have to take it to a dealer for a good scanning.
Old 09-03-2013, 04:30 PM
Rep:2968
Ask around at your local parts stores first. They may have the right scan too and they won't charge you a bill to hook up to it.
Old 09-03-2013, 04:34 PM
Revel Performance's Avatar
REVEL PERFORMANCE
Vehicle: MOPAR
Rep:931
My old 04 had a similar problem. I had my mechanic run the pcm, it had many stored codes dealing with the CC. Stupid ones, like holding the CC button for more than 1 sec or something goofy like that. At any rate, he cleared them out and everything was good as new.
sales@revelperformance.com
2004 1500, cruise control, servo
