Old 09-02-2013, 11:01 PM
tjenkins's Avatar
tjenkins tjenkins is offline
Vehicle: 2013 Ram
Trim Level: tradesman
tjenkins is on a distinguished road
Thumbs up Cab Marker Lights
Looking on allmoparparts.com at the cab marker light kit. It does not say in the description they are for 2013 trucks. Why not. Drill some hole. One wire to hook up. what could be different.
Tom in Michigan
Old 09-03-2013, 11:37 AM
topgun's Avatar
topgun topgun is offline
Vehicle: 2012 Ram 2500 CC 4X4
Trim Level: Outdoorsman
Rep:71
topgun will become famous soon enough
As of August, there is no plug and play kit for the 2013's. The lights themselves are the same but the wiring is different. Guys have been installing them on the 13's but had to run the wires themselves. They were getting power under the hood at the fuse box or a marker light. You can go through the firewall at the nipple under the main wire harness. It is there for cab access.
Hard to believe over a year and no accessory kit for these. Then again, the whole Mopar wesite is about one of the worst out there. Used to be able to look up all the available accessories for each model complete with install instructions. Good luck with that now.
Undercover SE, Corsa Cat Back, Amp Powersteps, Amp Bedstep, Bedrug, Mopar Tailgate Lock, Mopar Fold Flat Floor, Mopar Flat Rubber Splash Guards, Cooper AT3 285/70/R17's, S&B Intake, Moroso Catch Can
