Old 09-03-2013, 02:29 AM
Rogerwa's Avatar
Rogerwa Rogerwa is offline
Vehicle: 2009 Dodge Ram 1500 5.7l Crew
Color: Greystone
Rep:30
Rogerwa is on a distinguished road
Default HIghbeams don't work
Just picked up this 09 Ram 1500 last week and the only feature I didn't test was the highbeams. Sure enough I am driving a country road and when I push the switch nothing happens. If I pull the lever, the highbeams comes on as expected.
The lowbeams stay on when the switch is activated. Any hints on where to start? I did check the fuses, and didn't find a burnt one.
I believe the truck had a trailer brake acutator on it prior to it being traded in. I am wondering if some connections were disconnected while removing it.
Any tips on connections to check would be great.
2009 Ram 1500 Big Horn Crew Cab 5.7l Hemi
Twin Cities, MN
Old 09-03-2013, 11:57 AM
RogerRamJet's Avatar
God Bless Texas!
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
Sounds like all the wiring in in tack since the high beams do work when you pull back on the lever. I'm not sure if there is a relay that triggers that switch or if the lever itself is bad. I'm thinking one of those two are the culprit.
Old 09-04-2013, 01:44 PM
brondondolon's Avatar
brondondolon brondondolon is offline
Vehicle: 2009 Dodge Ram 5.7L hemi
Trim Level: 1500
Rep:177
brondondolon has a spectacular aura aboutbrondondolon has a spectacular aura about
in your head lamp do you have 1 bulb or 2? not counting the blinker bulb.
S&B CAI, Y-pipe muffler delete, Diablo intune, Hemifever, custom tune, 180 thermostat, BT oil catch can, smoked, tail light and 3rd breaklight, 5000k retrosolutions 55w HID headlights and fog lights, LED in all exterior lamps, red calipers. Future mods: 87mm TB, 3000 stall torque converter
Old 09-04-2013, 09:39 PM
Rogerwa's Avatar
Color: Greystone
Rep:30
Default Lamp cluster
Here is what the cluster looks like.
Twin Cities, MN
Old 09-05-2013, 01:53 PM
Trim Level: 1500
Rep:177
electrical is not my strong point. however if i was in your position id pull the bulb out turn the high beam on and then using a test light or volt meter check to see if its even getting power. unlikely that both bulbs went out at the same time but ive been in situations were the most obvious is the problem. thats where id start. did you buy the truck private party or from a dealer? if its from a dealer they should fix it in good faith. also you could check under the dash and look for disconnected or cut wires. i have no idea what one to look for but who knows.
Old 09-05-2013, 01:55 PM
Trim Level: 1500
Rep:177
btw you have the 2 bulb per lamp set up
Old 09-05-2013, 03:52 PM
Rogerwa's Avatar
Color: Greystone
Rep:30
I checked fuses and reseated relays, etc. I also checked underneath the column to check for disconnected wires.
The dash highbeam light does not come on when pushing the stalk forward. It does illuminate when pulling the stalk for passing.
Unless I am missing something, to me it comes down to the multifunction switch or that the comuter is not getting the signal. I have decided if i want to replace the switch to gt that out of the way first. I plan on taking apart the column plasitics to get a better look and to reseat the multifunction switch connection.
My daughter works at a jeep chrysler dealer so I could probably get them to put it on the scanner to chekc the computer.
Twin Cities, MN
Old 09-05-2013, 07:23 PM
Trim Level: 1500
Rep:177
did you buy the truck from a dealership?
Old 09-07-2013, 02:18 PM
Rogerwa's Avatar
Color: Greystone
Rep:30
Yes , I did. I am going to try that route, but the sales guy has already been less than helpful in post sales support, which is a disappointment.
I'd rather fix stuff than argue about it but I would not have driven it off the lot had i tested this feature and fond the problem. And I am sure they would have fixed it. But it only came with a power train warranty.
Twin Cities, MN
Old 09-07-2013, 08:40 PM
Trim Level: 1500
Rep:177
still though since you just bought it they should fix it "in good faith"
