Old 09-04-2013, 05:18 PM
Klingfuss Klingfuss is offline
Vehicle: 2014 Ram 1500 Laramie Crew 4wd
Color: Fire Red
Klingfuss is on a distinguished road
Measured my 2014 and the front is exactly 2" lower than the rear at all settings. Just raising the fornt 1.5" would help the looks of the truck a bunch. It's not about MPG, it's about looking like a truck
If someone finds someone that can level these please post it, I will do the same.
Old 09-04-2013, 05:32 PM
Alter Ego Trip Alter Ego Trip is offline
Vehicle: 2013 Laramie Limited
Trim Level: Limited
Rep:42
Alter Ego Trip is on a distinguished road
That's funny. I swear last time I measured mine, it was within a 1/2". I'll have to go recheck it and verify.
Old 09-05-2013, 12:24 AM
Explorer Rob's Avatar
Explorer Rob Explorer Rob is offline
Vehicle: 2013 Ram 1500 4x4
Trim Level: Laramie Longhorn
Color: Black Gold / White Gold
Rep:264
Explorer Rob is a jewel in the roughExplorer Rob is a jewel in the roughExplorer Rob is a jewel in the rough
I'm not sure how you're measuring the height difference but I'm assuming that you're measuring from the top of the front and rear fenders. I just measured mine with air suspension set to entry mode and found the front is 2.25 " lower than the rear. I'll have to wait until some other time to measure it in normal mode but I've never really noticed by looking at it from a distance it looking like it has too much of a rake. It has always looked fine to me. It might sit more level in normal height mode since in entry mode it is sitting on the rubber bump stops.
Old 09-05-2013, 01:24 AM
Trim Level: Limited
Rep:42
I measured it in normal mode. In exit mode it most definitely has a rake to it.
Old 09-05-2013, 08:04 AM
firemarshallvin's Avatar
firemarshallvin firemarshallvin is offline
Vehicle: 2013
Color: Black Gold Pearl
firemarshallvin is on a distinguished road
I believe that there is difference between front/rear. I will attempt to look for the literature I was reading a few weeks ago from RAM. I ordered the brochure and in it they describe the system, and included a bunch of measurement for both the front and the rear. They def move independent of one another, i.e.- it's marketed as say a 2" drop for entry/exit, well in fact the rear drops X.X and the front only X.X. I don't recall all the numbers now, but I was surprised how specifically different they were. I look and try snapping a pic, unless someone else finds theirs first.
2013 RAM 1500 Laramie Longhorn - Black Gold Pearl with all the trimmings. HEMI, 3.92, 8-Speed and Air Suspension
Add-ons:
14" Magnaflow, BAK FiberMax Tonneau, Misc Whelen Emergency Lights and Switchpak, 275/60R20 - BFG T/A KO2
Old 09-06-2013, 07:40 AM
skytop's Avatar
skytop skytop is offline
Vehicle: 2014 Dodge Ram
Rep:420
skytop is just really niceskytop is just really niceskytop is just really niceskytop is just really niceskytop is just really nice
Air suspension bleeds down when truck is turned off and ultimately rests on the rubber stops. Truck will be level at that time.
Old 09-06-2013, 09:47 AM
RJWNY's Avatar
RJWNY RJWNY is offline
Trim Level: Sport 4x4 CC 6'4"
Rep:56
RJWNY will become famous soon enough
http://ramforumz.com/showthread.php?t=146710
Old 09-06-2013, 10:56 PM
Rep:264
The only time the suspension should rest on the rubber stop is when the air suspension is placed in entry position. It will auto level itself a few minutes after shutting it off but that's it. Mine has sat in the garage for 2 weeks without the suspension bleeding down. I did have an occurrence a week after I got it where it lowered from off-road 2 to entry height while I was underneath taking pictures. I never did figure out why that happened and it hasn't moved on it's own since.
Old 09-20-2013, 07:16 PM
Color: Fire Red
Just checking on any updates of any tool to make the air suspension actually manually controlled. (Not returned to the nomal setting by speed) and to manually raise the front or rear independent of each other.
