Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram – 2009+ Dodge Ram Trucks > Suspension
Old 09-03-2013, 02:28 PM
taylor2644 taylor2644 is offline
Vehicle: 2009 1500 4x4
Color: silver
taylor2644 is on a distinguished road
Default Rear suspension problems unstable on hwy bumps
I have a 2009 1500 quad cab 4x4 hemi with 95,000 miles. The rear suspension on the hwy bounces all over when I hit bumps or go over bridges. It really doesn't feel like the shocks are bad as it drives fine on city streets. It's almost like it needs a bigger sway bar or pan hard bar is loose. Everything looks good and is tight. When I have weight in the bed it gets way worse! Is this a design problem with the new style coil suspension? Is there a good fix? I almost want to trade it in on a 2008 leaf spring truck.
Thanks for you help
Mike
Old 09-03-2013, 11:04 PM
brondondolon's Avatar
brondondolon brondondolon is offline
Vehicle: 2009 Dodge Ram 5.7L hemi
Trim Level: 1500
Rep:177
brondondolon has a spectacular aura aboutbrondondolon has a spectacular aura about
i have an 09 hemi ram id say it has more body roll then any other truck ive ever had but that is prob because of the 4 link rear suspension if im not mistaken. the shocks may need replacing. one thing that you could do is pull the shock off and see how hard it is to compress. taking it off and putting it back on should only take you 20 min. it should be pretty firm. i may not have the best answer but its the first thing i would do.
S&B CAI, Y-pipe muffler delete, Diablo intune, Hemifever, custom tune, 180 thermostat, BT oil catch can, smoked, tail light and 3rd breaklight, 5000k retrosolutions 55w HID headlights and fog lights, LED in all exterior lamps, red calipers. Future mods: 87mm TB, 3000 stall torque converter
Old 09-03-2013, 11:26 PM
Gantman's Avatar
Gantman Gantman is offline
Trim Level: Tradesman 4x4
Rep:974
I agree. It's probably time for new rear shocks. Bilstein 4600 series and a Hellwig sway bar should help a lot.
Old 09-04-2013, 12:15 AM
RogerRamJet's Avatar
I do it because I can!
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
I have to echo the others. Sounds like a shock issue. With 95K on them shocks, presuming they are original, it's time to change them. Folks don't realize just how out of shape and wicked bad a vehicle can get when the shocks start to go.
Old 09-04-2013, 01:00 AM
ArmyofOne's Avatar
US Army Retired
Color: Blue Streak Metallic
Rep:1195
That and most people don't realize shocks are a wear-out item. they have a useful life. 100,000 miles is about it, less on larger vehicles like trucks.
US ARMY-RETIRED
2015 Ram 1500 Laramie 4x4 Crew in Blue Streak Metallic Pearlcoat-30k miles-BF Goodrich Rugged Terrain T/A, Mufflex Muffler Delete, Mopar spray-in Liner, Mopar Mud Flaps, 20% tint, Mopar Side Steps, Best-Top Tri-Fold Bed Cover, DZ Tailgate assist, Total Load Control, AVS Visors and Bug Shield, K&N Drop-In, XenonDepot 5000k LED Headlamps in factory projectors.
Old 09-08-2013, 03:44 PM
TLC John's Avatar
TLC John TLC John is offline
Vehicle: 2006 Dodge RAM
Rep:17
TLC John is on a distinguished road
TotalLoadControl air suspension should help too.
Total Load Control™
Revolutionary Air Suspension for RAM 1500 2500 3500 4500 5500
Level Every Load with TotalLoadControl.com
Old 09-08-2013, 08:04 PM
Rep:2705
I have 93,000 miles on my '09
it always has from 700 to 1068 pounds in the bed, with no one in the cab
I am definitely due for shocks & possibly brakes
just need a 1/2 day to get it done
Old 03-10-2014, 01:00 PM
Jizanthapus Jizanthapus is offline
Vehicle: 2014
Jizanthapus is on a distinguished road
Look at the bushings on your control arms and panhard. If there is play anywhere, you'll be bouncing around any way it wants to go.
Old 03-10-2014, 01:11 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Mine will bounce around also when a heavy load is in there. I'd look at shocks as well.
Keep in mind this is sort of an annoyance of the suspension geometry though, the axle will shift slightly left to right during suspension travel. So when you hit a bumpt the vehicle is moving forward but the axle/body move left/right of each other. This gives you that weird swaying feeling. I actually was on the highway cruising slow around 65mph the other week and a ram pulling a trailer passed me at about 75mph and he hit a bump right next to me and I watched the body vs rear axle and could actually see it moving side to side. Hard to explain but it's just the geometry of it.
As armyofone said air bags should help stabilize it more too. I have the airlift 1000 kit on mine and it does help a lot.
Sean
Old 05-23-2014, 10:25 PM
Bill55AZ Bill55AZ is offline
Color: Steel
Bill55AZ is on a distinguished road
Long time ago a mechanic told me to use higher air pressure when towing. Sidewalls can flex if air pressure is low, introducing wobble.
He and I hauled firewood a lot, and he would actually put on his "working" wheels and tires. The tires were stiffer from having a lot of plys in the sidewalls and higher pressure, but there was NO wobble.
Retired USN, Vietnam, AO, Parkinson's stage 3, married, 2 kids, 7 grandkids,
Solar cooking nut
