2013 with 20" tires and factory lift - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Suspension
Old 02-28-2014, 02:46 PM
Bill55AZ Bill55AZ is offline
Color: Steel
Bill55AZ is on a distinguished road
Default 2013 with 20" tires and factory lift
I got the truck (4x2) and have since decided that I should have looked around for one without the lift, but would it have had 20" wheels/tires?
I want to go with regular ride height. Even with the step it is a tall truck.
I realize a front end alignment will be needed after the swap.
What exactly did they do to get this lift?
Retired USN, Vietnam, AO, Parkinson's stage 3, married, 2 kids, 7 grandkids,
Solar cooking nut
Old 02-28-2014, 08:46 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
zero details to go on bud. I don't think anyone can help you without some more details
Old 02-28-2014, 09:39 PM
Color: Steel
4x2, 2013 Ram 1500 extended cab, 20" wheels and tires, and some factory lift because of the 20" wheels and tires...what other details are needed?
If I knew what changes were made to get the lift, I can work on undoing it. If it is just longer springs, fine, I will look for standard springs. If it was done with spacers under the springs, I can remove the spacers. I hope they didn't do the lift with more complicated parts mods, as that can get expensive.
37" front, 39" rear, measuring ground to top of wheel openings.
I would like to at least drop the rear 2"....
Solar cooking nut
Old 05-25-2014, 11:47 PM
bigbody's Avatar
bigbody bigbody is offline
Vehicle: 2013 Ram 1500 Laramie
Color: Black/gray
bigbody is on a distinguished road
Think you are referring to raised ride height, not really a lift, and not much higher than any of the other trucks, the only ones that sit higher in the front are the 4x4 models
2013 RAM 1500 Laramie, sunroof, 3:55gears, undercover se, avs in channel, 30% tint all around
Old 05-26-2014, 05:39 PM
Hemi HFE Hemi HFE is offline
Vehicle: 2013 Ram 1500 HFE
Trim Level: SLT / HFE
Color: White w/ brown&beige interior
Rep:17
Hemi HFE is on a distinguished road
after I put '4" drop springs' (really only 2") on the rear of my truck,
I was level with all 4 corners at 35.25" +/- 0.25"
I agree, our trucks sit too high, espec. the 4x2 ..
looks like yu need a 2/4 drop kit
I like the McGaughys, bot on my RC/SB V6 it was only a 1/2
so I had to cut the springs to get the full 2/4
rear cam, Bluetooth/5.0, single CD, tow hooks, rear slider, bedliner, brake controller, IV hitch
Old 05-26-2014, 06:11 PM
Color: Steel
adding fuel to the fire.....drivers side is 1" higher than passenger side, front and rear.....maybe I will see the dealer tomorrow...
Solar cooking nut
Old 05-26-2014, 10:04 PM
Rep:17
lol dealer will tell you:
closer to level with a full tank of gas and you in the driver seat
Old 05-28-2014, 10:56 AM
Color: Steel
I found an ad on ebay for a raised ride pitman arm....
it appears that the pitman arm and 1" shorter shocks MAY BE the entire package...
Solar cooking nut
Old 05-28-2014, 12:23 PM
Moderator
Rep:2140
Your truck doesn't have a pitman arm..... it has a rack and pinion steering system.
Old 05-28-2014, 01:26 PM
Color: Steel
so it does....oops
Solar cooking nut
