Transmission lines - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 09-03-2013, 07:02 PM
MBR MBR is offline
Vehicle: 2010 Ram 1500 Sport
Rep:66
MBR will become famous soon enough
Default Transmission lines
Anyone happen to know which transmission line is the feed and which is the return where the go in at the trans?
Old 09-03-2013, 07:46 PM
Sparkyy Sparkyy is offline
Vehicle: 2007 Dodge Ram 1500 Quad Cab
Color: Metallic Blue
Sparkyy is on a distinguished road
Not sure if you have the same tranmission as the 3rd gen transmission but maybe this picture can help, I got it from another forum.
Also, run the truck and check the lines, one will be cooler was another tip I read.
Old 09-04-2013, 07:31 AM
TransEngineer TransEngineer is offline
Vehicle: N/A
Rep:518
TransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of light
What engine / trans do you have? If you have an RFE transmission (545RFE), the upper line coming out of the trans is the "to cooler" line, and the lower line (at the trans end) is the return line.
