Old 09-23-2013, 11:20 AM
cupcars's Avatar
cupcars cupcars is offline
Vehicle: 2012 Ram 1500 4x4
Trim Level: QC Express
cupcars is on a distinguished road
Originally Posted by xsdbs View Post
:smile down: Do not try this update if you have a SW version below 23.04.33
If you do, you'll damage the radio. Unfortunately I did while trying to see if the 50.xx is compatible with 20.02, it's not and there are no error indicators of the incompatibility. :smile down:
Hmm... I replace the 130S RES radio in my truck with an RBZ out of a 2011 Ram 2500. I already had Uconnect. The current software in my RBZ is 20.02.01
Has anyone tried updating theirs to ver 33, then updating to ver 50? I also have a Lockpick. Don't want to brick my RBZ.
Thanks!!
Old 09-23-2013, 12:21 PM
EdmontonRam EdmontonRam is offline
Vehicle: 2011 Ram Crew Sport
Trim Level: Sport Crew
EdmontonRam is on a distinguished road
Just wanted to add my success. 2011 Ram 1500 Sport Crew, 430 RBZ (non nav) w/ lockpick newest model. Version started at 33.01.23 and went to the new 50.00.07 with no problems. Even left the lockpick hooked up. One feature I am not sure about now is the "Camera Delay" that is now in system setup.
Old 09-23-2013, 01:44 PM
cupcars's Avatar
2011 RBZ w/ Version 22.02.01 software.
I ran the ver 33.01.23 update. When I loaded the disc it asked if I wanted to update from ver 20.02.01 to 33.01.23. I picked yes. it went thru two processes (see pics) then the screen went blank. I waited about 10 minutes to see if it was going to do anything....nothing. I tried turning it on, eject the disc,... nothing, it was dead!
I removed the radio fuse under the hood for a few seconds, put it back in and turned the key on and the radio was alive again. It did update the software (see attached pics). It never asked me to "Update baseline data files on HDD" per the install instructions. Not sure if that needs to be installed and how to do it?
I plan on installing Ver 50 so I can have the black screen. I will post when I decide to do it. I have Lockpick 5 installed and I did not remove it for this software update.
Before:
Process 1
Process 2:
After:
Old 09-23-2013, 03:14 PM
cupcars's Avatar
Well I decided to update to Ver 50 in my RBZ. This time it asked to update the baseline data files on the HDD, I told it yes. Then it asked to update from ver 33 to ver 50, I picked yes. It ran thru it's processes like when I updated to ver 33 and it went dead again just like in ver 33...... I pulled the fuse again and the radio is back working again and YES it has a black background!! See pics.. I did not disconnect my Lockpick 5 fot this update.
Recap: I took an RPZ radio from a 2011 Ram 2500 & replaced my factory 130S RES with it. Updated from 20.02.01 to 33.01.23..... then updated from 33.01.23 to 50.00.07
Old 09-23-2013, 03:22 PM
Mopar Big Horn's Avatar
Mopar Big Horn Mopar Big Horn is offline
Vehicle: 2011 RAM 1500 crew cab 2wd
Color: PR4 Flame Red
Rep:130
Mopar Big Horn will become famous soon enoughMopar Big Horn will become famous soon enough
Guys with the RBZ unit did yall just burn version 50 to a disc? Mine has version 33 and I have already burned version 50 to a disc but not sure if I need to burn anything else. What is the baseline files?
Check my mod list.
Old 09-23-2013, 03:54 PM
Yep. Burnt the ISO file and it made a readable disc. Put it in and it asked to update base files. Hit Yes, updated. Screen went black for a minute and it restarted. All ok after that.
Old 09-23-2013, 06:05 PM
Rep:130
Thanks EdmontonRam just finished the update, went perfect, definately like the update thanks to all the members who had input on how to do update.
Check my mod list.
Old 09-23-2013, 06:11 PM
Rep:130
Forgot to add, does anybody know what the camera delay does? I checked the box but camera seems to work the same.
Check my mod list.
Old 09-23-2013, 06:22 PM
Stump3r's Avatar
Stump3r Stump3r is offline
Rep:1266
If the camera delay works like it does in the 13's the reverse camera will stay on an additional 5 seconds when you shift it into drive.
Big Red my old 2011 Sport
Old 09-24-2013, 07:42 AM
Rep:130
You are correct, the camera mode stay active after you shift out of reverse. Not sure why but my screen will go black with a red X in the top right and will stay there until I hit the X. Needless to say I turned it off.
Check my mod list.
