Old 09-13-2013, 03:07 PM
Spelled Spelled is offline
Vehicle: 2010 Dodge Ram Crewcab
Trim Level: Bighorn
Spelled is on a distinguished road
Default Another Newbie Tire Question
Ive been searching for awhile and can't find the exact answer im looking for...so here I go...
Truck: Stock 1500 4x4 Crew Cab Longhorn
Looking to do a level with the Bilstein 5100's at max height. Plan on keeping stock 20" rims and have pretty much settled on the 295-65-20 Nitto Trail Grapplers. I believe in my state (VA) to pass inspection, my tires can't rub. I have seen threads that people have used no spacers...1/4" spacers....1" spacers....
What spacers (or other device) do I really need to keep these bad boys from rubbing?
With spacers, can I go with a larger/wider tire? If so, what size(s)?
Thanks in advance from a newbie!
Old 09-13-2013, 03:34 PM
Moderator
Rep:2140
You might have rubbing issues with a 295 wide tire. Typically sticking with a 285 is your safest bet but some guys are running 305 wide tires on stock rims and getting away with it. Every truck is just slightly different.
With Bilsteins maxed you can run up to a 35x12.5 tire. If you're using the stock rims you will need 1/4" spacers to clear those. But a Nitto Trail Grappler might still give you issues since they actually measure about 13.5" wide. Your other option would be to go with aftermarket rims but you'll be sticking out past your fender quite a ways and probably won't pass inspection.
I'd recommend running the 295/65 tires but have easy access to 1/4" spacers in case you do have rubbing issues. If they rub you will need the spacers right away, no question. Otherwise you'll destroy your sidewall.
