Old 09-09-2013, 06:32 PM
GP252 GP252 is offline
Vehicle: 2014 ram 1500 sport black
Trim Level: sport
GP252 is on a distinguished road
Default leveling and tires
Guys i am presently ram 1500 owner stock. I have a new 2014 1500 sport on order should be here few weeks. I want to level the front and add some nice rims and tires. I have no clue about leveling or who even would do it for me in nassau county ny? Rims i picked are Fuel Mavericks 20x9 with 1" offset and Nitto Terra Grappler 305/55-20 havent bought anything yet wanna make sure they are gonna be ok? Any help would be great thanks Greg.
oh i also think im gonna do fender flares if that makes a difference.
Old 09-09-2013, 07:04 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2032
The best way to level is with the Bilstein 5100 adjustable struts. They are much better than the standard spacer type leveling kit IMO and will give you a better ride quality. They have height settings from 0" (stock height) to 2.8" of lift. Contact the guys at Bully's Performance for pricing on the Bilsteins at sales@bullysperformance.com. Be sure to mention that you're a forum member for discounted pricing.
I'm assuming you meant a +1mm offset, not 1". 20x9 +1 offset with 305/55/20's will fit on there no problem. You'll probably be sticking out about 3/4" past the fender so the fender flares will cover them up.
Old 09-09-2013, 07:11 PM
Trim Level: sport
yes you are correct +01 offset my bad thank you. any other suggestions im all ears thanks again
Old 09-11-2013, 08:15 PM
Rockyd831's Avatar
Rockyd831 Rockyd831 is offline
Vehicle: 2013 Dodge Ram 1500 Sport
Rep:33
Rockyd831 is on a distinguished road
Would a 20x9 wheel with a 18mm offset fit?
Of course using the same size tire being 305/55/20
Thanks
2013 Ram 1500 CC - Silver Grey Metallic,2.5" Level,OEM Fender Flares
More to come.....
Old 09-11-2013, 08:20 PM
Thanks
It won't fit as +18 is 1mm off from stock and stock 275 are pretty close to the a arm as is
Old 09-11-2013, 09:02 PM
Rep:2032
Yup, what Amdrew said above. You won't be able to fit a 305 wide tire on a 20x9 +18 offset.
Old 09-11-2013, 09:06 PM
Rockyd831's Avatar
Rep:33
So what is the offset of the stock rims?
Im guessing the ones I mentioned above are -1mm offset.
Which means they will be closer to the vehicle.
As opposed to +1mm which would mean they stick out futher past the fender?
Thanks
More to come.....
Old 09-11-2013, 09:13 PM
Rep:2032
Stock wheels are 20x9 +19mm offset. The more negative the offset the further the wheels stick out providing more clearance to the inside suspension.
Old 09-11-2013, 09:17 PM
Rockyd831's Avatar
Rep:33
So with my truck being leveled 2.5inch
I should be able to fit those on without having any rubbing issues.
Again on a 305-55-20
Thanks guys. I really appreciate all the help being provided here
P.S If not the 305 tire what would be the biggest tire I could fit. Or the one that would look best.
I am doing this strictly for look. Have no plans to off road anytime soon
More to come.....
Old 09-12-2013, 01:38 AM
Rep:2032
The widest you can go on stock wheels is a 285 (for most people at least). You will need 1/4" wheel spacers or aftermarket rims with the correct offset to fit anything wider.
You can fit up to 35" diameter tires with your 2.5" leveling kit.
