92 D150 no start - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 08-11-2013, 03:38 PM
ram86 ram86 is offline
Vehicle: 2012 RAM EXPRESS SC 1500 2WD.
Trim Level: EXPRESS 1500 SC 2WD.
Color: MINERAL GRAY
Rep:12
ram86 is on a distinguished road
Default 92 D150 no start
I been looking at this it has a 5.2 and no fuel pressure, no spark, and the asd relay isn't clicking on when key is turned on, and all the fuse links underhood on drivers side below the relays is good. could this problem be the ignigtion switch or does anybody on here have electrical diagrams?
Old 08-14-2013, 10:54 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:99
Starter relay. small silver box on driver side inner fender near ASD and other relays.
Old 08-16-2013, 06:34 AM
Color: MINERAL GRAY
Rep:12
Thanks Gen1dak. my diagnosis to this point is the problem lies in the ground circuit of the asd relay. there is ign., and battery current. but no output and that is because there is no ground. when i ground the relay it the output comes on. but it still doesn't crank, it has fuel pressure when i ground it but no spark from the coil. I suspect the comp.
Old 08-16-2013, 06:29 PM
Rep:99
When you say it doesn't crank, do you mean the starter isn't engaging, or it IS engaging, but the engine just spins with no life?
Old 08-17-2013, 09:46 AM
Color: MINERAL GRAY
Rep:12
Sorry about that, my bad and i even new better. Crank means to turn over and no start means just that. It.s a no start, it's cranks over fine.
Old 08-23-2013, 05:33 PM
Nabby Nabby is offline
Vehicle: 1991 Dodge Ram
Trim Level: Unknown
Nabby is on a distinguished road
I don't know how different your 92 is from my 91, but my 91 FSM states: "The engine controller monitors the distributor pick-up signal to determine engine speed and compute injector synchronization. If the controller does not receive a distributor signal when the ignition switch is in the RUN position it will de-energize (remove ground) the ASD relay. Battery voltage will not be supplied to the fuel pump, fuel injectors, ignition coil, and O2 sensor heater element. The engine controller energizes the ignition coil through the ASD relay. The engine controller will not energize the ASD relay until it receives input from the distributor pick-up."
Old 08-24-2013, 02:21 AM
Rep:99
It's kind of a chicken or the egg thing. If the camshaft position sensor, aka distributor pickup, is bad, you'll get no signal to the computer which kills the ASD. However, a bad computer will also lead to a no-power ground for the ASD.
Old 08-27-2013, 08:57 PM
Color: MINERAL GRAY
Rep:12
another thing to add to this is there also is no check engine light.
Old 09-01-2013, 01:59 AM
Trim Level: Unknown
You can still try checking for stored codes, I forget how it's done, something to do with turning the key on and off a few times and the CEL will blink codes at you.
Old 09-01-2013, 03:09 AM
RogerRamJet's Avatar
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
Cycle the key 3 times. Starting in the off position, turn in on, off, on, off, on and leave it. Have a pencil and paper ready because the cluster will flash any codes. Say it has code 438 stored. The light will flash four times, then pause, 3 times then pause, 8 times then pause. It will repeat the sequence, I think 3 times, or until you turn the key off.
