tonneaucovered.com
Old 09-04-2013, 09:13 PM
HeMi BosS HeMi BosS is offline
Vehicle: 13 Hemi Ram Sport
HeMi BosS is on a distinguished road
Default suspension lift ? helpp
i have a 13 ram sport 1500, and wondering if anyone has a 6 or 8 inch lift ?
i was thinking of 8 inch lift, does anyone know any 8 inch lift thats affordable and worth it?
also would a lift kit void warranty ?
Old 09-04-2013, 09:20 PM
Astartes Astartes is offline
Vehicle: 2010 4.7l v8 4x4
Rep:160
Astartes has a spectacular aura aboutAstartes has a spectacular aura about
Try getting a 6" rough country lift with bilsteins 5100 adjustables for the front struts. run you about 1600 ish total, not including installation. Hit up fastnugly from bullys performance, his company sells them.
Greater love has no one than this, that a man lay down his life for his brothers. -John 15:13
My Mods
Old 09-04-2013, 09:32 PM
mrolow's Avatar
mrolow mrolow is offline
Vehicle: 2013 Ram 2500 4x4
Color: Prairie Pearl Clearcoat
Rep:132
mrolow will become famous soon enoughmrolow will become famous soon enough
You did not specify if 2 or 4 wheel drive. 6" is the most I have seen for 4 wheel drive, 7" for 2 wheel drive.
Mods: Too many to list
Old 09-04-2013, 11:11 PM
4x4.................
Old 09-04-2013, 11:16 PM
so with the blistens their adjustable right? would i be able to make it an 8 inch lift?
and also hows the ride with rough country compared to stock ? hows it so cheap ?
Old 09-05-2013, 12:25 AM
brandonjansen's Avatar
Trim Level: Laramie Limited
Rep:2101
Max suspension lift you can get for a 1500 is 6" and then add Bilsteins on the front to level the truck. 1.4" on the Bilsteins will put you pretty much dead level. If you want to go higher for more lift height then you will want to add rear coil spacers as well to avoid Cali lean.
Check out Rough Country and BDS for lifts. Rough Country is definitely the cheapest and tons of guys are running it with no problems at all. I had no complaints with mine on my 1500. With the lift and Bilsteins the ride was even better than stock. Again, absolutely no complaints there. It handled and drove very well!
As Astartes said, contact Andrew, Jeremiah, or Eric at sales@bullysperformance.com. Be sure to mention that you're a forum member and were referred by us and they'll hook you up with some great pricing on everything you need.
Old 09-05-2013, 03:08 AM
i looked at bds its a little too pricey for me, im pretty interested in the rough country lift though, and also on their website you can purchase additional shox, would i need to buy them for a better ride ?
my dealer installed a leveling kit, i think its a 2.5 inch block because the truck looks level so would i have to purchase blistins ? or seperate shox ?
lastly, does intalling a lift kit void warranty ?
thanks for the help.
Old 09-05-2013, 12:10 PM
Rep:2101
Rough Country is definitely a great kit if you're looking to stay under a tighter budget. I'm not sure what additional shocks you're talking about purchasing with the kit. It comes with the rear shocks already and the front of a Ram 1500 uses a strut assembly. I know the Rough Country kit does have the option to add kicker bars to the kit, is that maybe what you're referring to?
When you install the lift kit you will need to remove the 2.5" leveling spacer that the dealership installed on your truck. You can not stack spacers. The RCX kit will come with a new (much larger) spacer to put on top of your strut. If you want to have a level truck when it's lifted or add any additional lift you will need the Bilsteins as well. Otherwise you will have approximately 2" of rake with the stock RCX kit (no Bilsteins).
A lift kit will void warranty on many of the suspension components of your truck (obviously since you are changing them all). But it will not void the warranty on your whole truck. The only way warranty can be voided is if the dealership can prove the part you added caused the problem. So for example if you have an issue with your power windows not working obviously that has nothing to do with the lift or any other mods you've done so it will still be covered.
Old 09-05-2013, 03:54 PM
alright im deciding on the rough country right now,, i was browsing the web and u saw this site with cheap procomp lifts could you check it out ?
http://www.pcscustom.com/searchresults.asp?cat=5087
http://www.pcscustom.com/searchresults.asp?cat=5089
http://www.pcscustom.com/searchresults.asp?cat=5522
http://www.pcscustom.com/searchresults.asp?cat=5524
Old 09-05-2013, 04:15 PM
Rep:2101
I'm not really a fan of the rear lift set up on ProComp kits... instead of using longer springs they just use a big spacer. It's a little half assed IMO. Other then that they do make a good product.
Obviously all those different kits come with different components and different ways of lifting. You'd have to decide yourself exactly what you want to go with and how good of a lift you want.
