Old 09-04-2013, 09:58 PM
bsmith79 bsmith79 is offline
Color: Gray
bsmith79 is on a distinguished road
Exclamation Wierd A/C Recirculate Issue. Anyone else?
I have a 2013 Ram 1500 Express. One thing I noticed is that the recirculate seems to stay on all the time unless I press that button off and then on again. I know that if the temp control is turned all the way to the coldest setting, it turns on max a/c and puts it in recirc mode. But if I have the temp turned back a notch, the recirc stays on, even if the recirc light goes out! When this occurs, I have to press the recirc button on, then off again to get the vent out of recirc and back to drawing in outside air. And even when I get the system out of recirc, if I shut off the truck and then restart it, it goes right back to recirculate! (and the recirc light remains off!) What the heck? Anyone else have this issue? Am I missing something? Do I need to go back to the dealer? Other than this, the truck seems to be working fine, knock on wood.
Old 09-04-2013, 10:14 PM
2002kasner 2002kasner is offline
Vehicle: 2013 Ram
2002kasner is on a distinguished road
I have very similar issues with my express crew. Mine happens when I turn the temp of ac up and then turn it back down. It's like it doesn't know that I've turned the ac back to a lower setting and shuts off the condensor fogging up the inside of the truck
Old 09-04-2013, 11:27 PM
bigralphy bigralphy is offline
Vehicle: 2013 Ram Sport
Rep:39
bigralphy is on a distinguished road
Mine does the same thing
Old 09-05-2013, 09:52 PM
Color: Gray
Well I am glad to hear I am not the only one with this issue. It is not really a problem, more of an annoyance. I wonder if anyone has had the problem looked into and if so, was it fixed? If so, what fixed it?
Old 09-05-2013, 11:54 PM
skytop's Avatar
skytop skytop is offline
Vehicle: 2014 Dodge Ram
Rep:420
skytop is just really niceskytop is just really niceskytop is just really niceskytop is just really niceskytop is just really nice
You want recirculation to be on all the time. It is the most energy efficient method of chilling the cabin and saves wear on your A/C to boot.
Why have your A/C system work extra hard chilling very warm/humid outside air? Recirc will have an easier task cooling and removing humidity from already processed air.
Old 09-06-2013, 07:54 AM
Scott H Scott H is offline
Vehicle: 2014 Ram 1500
Color: Maximum Steel
Rep:12
Scott H is on a distinguished road
Mine does the same thing. When running with AC I can hear the recirculation come on all by itself with no lights. A couple of times when driving without AC on I could tell AC had turned itself on, also without indicator lights!
Had it checked when in for service but technicians could't get an error code. Probably because it doesn't do it all the time.
Scott
Old 09-06-2013, 10:47 AM
shepcam shepcam is offline
Vehicle: 2013 CC Sport 4x2
shepcam is on a distinguished road
I have the opposite problem,, mine will not stay on. I can push the recirc button with the a/c on low temp, turn the truck on and it is back off. No matter what I do it always turns off when I shut the truck off. The same thing happens with the vented seats, I can have it on full setting and when i turn the truck back on its on low. I will have the dealer check it on my next oil change.
Old 09-06-2013, 04:40 PM
Vehicle: 2013 Ram
Had it happen to me again today on my way home had the ac on the first not h above max ac then when I went to max ac it just started shooting semi moist warm air back out at me. Called the dealership and its going in next sat at 9am
Old 09-06-2013, 07:29 PM
BigOrange BigOrange is offline
Vehicle: 2013 RAM 1500
Trim Level: EXPRESS QUAD CAB
Color: BRIGHT SILVER
Rep:17
BigOrange is on a distinguished road
Same thing here..... keep us posted!
Magnaflow 14" SI/DO, No Resonators, K&N Drop-In Filter, De-badged.
Old 09-09-2013, 09:41 AM
Color: Gray
Well, I found that if I get in my truck and turn the recirculate on and then off one time, it seems to work fine after that even with the max a/c control.
air conditioning, climate control, recirculate
