Old 09-09-2013, 01:04 PM
GEOPYR8's Avatar
GEOPYR8 GEOPYR8 is offline
Vehicle: 2013 Dodge Ram 1500
Trim Level: Express QuadCab 4x4
Color: True Blue Pearl
Rep:44
GEOPYR8 is on a distinguished road
Somethings not right as I've had no issues with mine. Recirculation turns on with the A/C max and off with 1 notch up. Works right turning it on or off manually. I use my A/C everyday. These trucks have some weird program glitches.
That's my storie & I'm stickin to it!
Old 09-09-2013, 01:56 PM
AirborneSilva AirborneSilva is offline
Vehicle: 2013 Ram Sport
Rep:74
AirborneSilva will become famous soon enough
Originally Posted by shepcam View Post
I have the opposite problem,, mine will not stay on. I can push the recirc button with the a/c on low temp, turn the truck on and it is back off. No matter what I do it always turns off when I shut the truck off. The same thing happens with the vented seats, I can have it on full setting and when i turn the truck back on its on low. I will have the dealer check it on my next oil change.
Mine does the same thing, wish it would stay on!
2013 Ram Sport
1976 Corvette L82
Old 09-11-2013, 10:55 PM
2002kasner 2002kasner is offline
Vehicle: 2013 Ram
2002kasner is on a distinguished road
Ac went out again today. Same issue as before. Notch above max cold blower on the front vents only and recirculating light was off... This is some bs and can't wait to go to the dealer Saturday!!
Old 09-12-2013, 06:14 AM
bsmith79 bsmith79 is offline
Color: Gray
bsmith79 is on a distinguished road
Be sure and let us know what the shop said or did.
Old 09-12-2013, 08:00 AM
NCBEAST NCBEAST is offline
Rep:16
NCBEAST is on a distinguished road
Mine does the same.....let us know if they are able to fix.
Old 09-12-2013, 08:06 AM
Vehicle: 2013 Ram
Is no one else not having issues? And if you are not going to take it in?
Old 09-14-2013, 02:58 PM
Vehicle: 2013 Ram
Default Update!!!
Customer states a/c blowing warm air
Inspect test and found codes P0532 and P0533.ac pressure high ac pressure low/found wire @ radiator support pinched repaired wire and retest. Operation ok at this time.
Well turns out during assembly they pinched a wire putting it all together. Ac works great now! My build date is 11/12 for anyone else experiencing issues!
Matt
air conditioning, climate control, recirculate
