200k miles...what maint. would you do? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.7L V8 Specific Topics
Old 09-04-2013, 11:33 PM
mcompton1973 mcompton1973 is offline
Vehicle: 2004 Ram 1500 SLT
mcompton1973 is on a distinguished road
Default 200k miles...what maint. would you do?
I will be honest. I am NOT the worlds best preventative maintenance guy. But my truck is about to hit 200k miles. I bought it a little over a year ago with about 150k and use it to travel as a salesman. Almost all miles are highway. I had planned on trading it off (normally I only drive Fords), and finally just realized that it seems solid. In 15 months I have had to put gas in, and change oil, and replace one wheel bearing (I know i should have done both but money didnt allow for it at the time. I cant ask for a lot more than that...but MPGs are starting to drop...and I figure if I get all the maintenance back up I will get some of that pep and mpgs back.
Should I switch to full synthetic oil?
I know I need shocks. Any other front end things I should test for? I am putting breaks on tomorrow, so any quick little 'tests' I can do I will while I have it on a jack stand.
Flush Transmission? Radiator? Any other fluids you would mess with?
Also I know I need spark plugs and wires. I know there are 16. Is there a consensus best brand of plugs or wires? I am hoping they have been done once before...but I really dont know.
Any other suggestions? Thanks.
Old 09-05-2013, 12:06 AM
RogerRamJet's Avatar
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
The best brand is the OEM, which is NGK for the HEMI, I believe. The part number should be on the gap sticker. As far as fluids, change them all out as time and money permits. The sooner the better. Synthetic will definitely be a good idea, but again, as money permits. Shocks are easy to replace and they're not too expensive. While you've got it up in the air, with the tires on, grab the tires and push/pull on opposite sides. What you're checking for is to see if there is any play in the bearing and/or the lower ball joint. The ball joints in our 3rd gen Rams are famous for going south. Check all your seals and gaskets for leaks. Other than that, keep doing what your doing and you should get a lot more life out of the beast.
Old 09-05-2013, 12:26 AM
shawnu's Avatar
shawnu shawnu is offline
Vehicle: 2012 Ram
Rep:517
Blinker fluid!! Cant forget that!! Lol.
Nahhh what has been mentioned pretty much sums it up.
Good luck!!
12 Flame Red RCSB Express- Sold 3/2015
17 Blue Streak R/T Ordered 5/23/2017
Delivered 6/22/17
Old 09-05-2013, 12:42 AM
Rep:2968
Good luck!!
Damit! Muffler bearing grease too. Can't forget that.
Old 09-06-2013, 06:15 AM
wchnu's Avatar
wchnu wchnu is offline
Vehicle: 2003 Dodge Ram
Color: red/grey
Rep:26
wchnu is on a distinguished road
Rotate the air in the tires?
"The very atmosphere of firearms anywhere and everywhere restrains evil interference - they deserve a place of honor with all that's good.
George Washington
Old 09-06-2013, 09:07 AM
Rep:2968
That's always good. Gotta keep fresh air in them so they can percolate.
Old 09-07-2013, 12:31 AM
wchnu's Avatar
Color: red/grey
Rep:26
In a serious note. How about timing chain?
George Washington
Old 09-07-2013, 01:31 AM
Rep:2968
If it was a belt, I would say most definitely. But chains usually don't break... usually. With that said, why not? And since you're gonna have the coolant drained anyway, do the water pump as well. Good idea, wnchu!
