Old 09-05-2013, 10:24 AM
gsxrfarm's Avatar
gsxrfarm gsxrfarm is offline
Vehicle: 2012 ram express
Trim Level: express
Rep:47
gsxrfarm is on a distinguished road
Unhappy bout to give up
so I installed my bully dog a few months a go every thing seamed to go well other than the labor knock when it was under a load like going up a hill in high gear low speed .. well since then I put a catch can on it and nothing has changed .. the only way I can get it to stop is to add octane booster to it and run it like that , keep in mind its on the regular tune and I run 93oct in the truck I get it from the same place I always did prior to the install and its the same gas I run in my cts had have no issues .. does anyone have any last ideas ???!
2012 express , s&b cai, magnaflow, bullydog, catchcan 24" rims
Old 09-05-2013, 10:50 AM
Asur Asur is offline
Vehicle: .
Rep:4371
What Ver of the tune are you running?
if your running the 019 tune and your still having issue then you have a 30day return policy on the unit, send it back, Return it, some vehicles just can't work proper with modified tunes, it could be a whole bunch of things put together that are giving you this pinging issue, could be the gas, elevation, truck computer, engine specs, etc etc all mixed together and giving you issues, Try the Diablo and that being said get it from hemifever and have him make you a tune for your truck. He can adjust it to be very specific to your setup and issues. Cost will be a bit more if you go this route.
Old 09-05-2013, 11:09 AM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
93 gas with ethanol can cause knock as well as it isn't true 93 gas.
Old 09-05-2013, 12:41 PM
Piston Slap's Avatar
Piston Slap Piston Slap is offline
Rep:42
Piston Slap is on a distinguished road
I returned my BD for just this reason. It didn't work out for me. On my truck, the regular tune would knock (under load) with 93 octane. I spent too much of my time with tech support and tried three different firmware versions - all to no avail. And as you can see by your own experience the catch can theory doesn't work.
I wouldn't keep driving it while it's doing that. It's unreasonable to have to run octane booster + catch can to keep the truck from knocking. It's simply an issue of too much timing.
Old 09-05-2013, 07:40 PM
06 BigHorn's Avatar
06 BigHorn 06 BigHorn is offline
Vehicle: 2012 Dodge Ram
Trim Level: Express Quad Cab
Color: Deep Cherry Red
Rep:153
06 BigHorn has a spectacular aura about06 BigHorn has a spectacular aura about
Sounds like another case of the pinging poodle. Switch that tuner for a Diablo
It's a truck, not a cream puff
Old 09-12-2013, 10:02 PM
kingbrad22 kingbrad22 is offline
Vehicle: 2012 DODGE RAM
Trim Level: SPORT
Color: WHITE
kingbrad22 is on a distinguished road
i just ordered the Diablo with the hemifever tune. Should get it tomorrow. Cant wait to try it out and let everyone know how it turned out.
