Place your Ad Here!
Old 09-05-2013, 05:13 PM
ryan2001 ryan2001 is offline
Vehicle: 2011 Ram 1500 4x4
Trim Level: Outdoorsman
Color: Hunter Green
Rep:31
ryan2001 is on a distinguished road
Default 2011 Hemi Random Bad Knock-Fan Clutch
HI all
My 2011 Hemi Ram has all of a sudden developed what sounds like a knock but it is random and very loud. Sounds like a dull thud only at idle warm or cold. I was going to pull the belt off and start it thinking it might be a idler pulley or belt tensioner and noticed while the engine was HOT after driving from KC to St. Louis the fan was spinning slow....I was able to actually grab it and stop it by hand while the engine was running and could feel the knock in my hand through the plastic fan. Anyone heard of this and do you think my fan clutch may have given up the ghost? Truck has 67K miles FYI.
Old 09-05-2013, 06:10 PM
Color: Hunter Green
Rep:31
well scratch that....pulled the belt off and started it up still knocks. seems to be coming from the bottom of the engine possible wrist pin or Torque Converter. Happens in all gears only at idle.
Old 09-10-2013, 05:18 PM
Mac hemi Mac hemi is offline
Trim Level: SLT BigHorn
Color: hunter green
Mac hemi is on a distinguished road
check the harmonic balancer for separation.
Old 09-10-2013, 05:50 PM
oldhp's Avatar
oldhp oldhp is offline
Vehicle: 2014 Express 3.6/8 speed auto
Color: WHITE
Rep:902
oldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to behold
Take to dealer for warranty. Have then document noise. Too many HEMI's have this problem.
2016 Challenger R/T Hemi 6-speed.
2012 Equinox 2.4...Wife's Ride
2014 RAM 3.6/8 speed/3.55 gears........Gone.
"Life's hard, it's harder if your stupid."
How would you know?
Old 09-12-2013, 01:38 PM
Color: Hunter Green
Rep:31
Here is the latest after 5 days in the shop....bad lifter or lifters. They are telling me that the lifters may have rotated in the bore and will need to be replaced. Pulling both heads and doing the work. The more i dig into this it appears that this is a more common problem and a fairly in depth fix. I am not talking about the valve Tick....i get that but this is a knock that sounds like a rod bearing and amplified via the exhaust. The Mopar brand has lost a little luster in my book as valve train components should last longer than 60k miles. I do understand that sometimes bad parts go into cars and with 16 per engine there are a lot out there but really?
