Old 09-05-2013, 08:38 PM
Baumann01ram Baumann01ram is offline
Vehicle: 2001 Dodge Ram 1500
Baumann01ram is on a distinguished road
Default v8 to V10 swap
okay so i am swapping a 8.l v10 out of a 97 2500 over into my 94 1500 that originally had a 5.9l. i understand i have to swap the whole drivetrain trans/transfercase/axles along with it but my question is do i have to swap the wiring harnesses, i have swapped the guauge clusters and computer but ive been wondering if the harnesses are the same that go through the firewall into the cab? any help would be greatly appreciated! thanks
Old 09-05-2013, 09:27 PM
maust1's Avatar
maust1 maust1 is offline
Vehicle: 2013 Ram
Trim Level: Tradesman
Color: mineral grey
Rep:355
I believe your going from OBD1 to OBD2 and you most likely will need to swap the harness.
Old 09-05-2013, 09:40 PM
Okay, yeah the obd ports are different, so i need to swap out the complete harness out of the cab?
Old 09-06-2013, 02:33 AM
maust1's Avatar
Vehicle: 2013 Ram
Color: mineral grey
Rep:355
You could change out the plugs and hope it all works or you could swap the harness and know it will work. If I were doing the work I would change the harness.
Old 09-08-2013, 02:27 PM
Well i went ahead and swapped harnesses, guess we'll see if it works when i get the motor all hooked back up
Old 09-08-2013, 05:52 PM
maust1's Avatar
Vehicle: 2013 Ram
Color: mineral grey
Rep:355
Good luck I hope it works.
v10, v10 swap
