Best throttle body? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 09-05-2013, 09:30 PM
Jhouse's Avatar
Jhouse Jhouse is offline
Vehicle: 2014 ram
Color: blue streak pearl
Rep:163
Jhouse has a spectacular aura aboutJhouse has a spectacular aura about
Default Best throttle body?
Im about to order a tb. Whos got the best out there? I have a cai flowmaster and ds trinity so far
K&n cai, bt catch can,moes 87mm throttle body,flowmaster super 44, hemifever 89 tune, 20% tint front 15% rear,egr vent guards, black weatherguard toolbox, debadged,re audio 10" in fox box with amp rack, retroshop hid's 6000k in fogs and lows, custom mopar badges
Old 09-06-2013, 08:29 AM
TBILLIOT's Avatar
TBILLIOT TBILLIOT is offline
Vehicle: 2011 dodge ram 1500 quad cab
Trim Level: sport 4x4
Color: hunter green pearl
TBILLIOT is on a distinguished road
Probably moes performance
Old 09-06-2013, 08:33 AM
Grubrunner's Avatar
Rep:3883
Knock on the door at the [good] folks at Bully's Performance.
There's a review in my sig.
Good luck.
Grub out!
Old 09-06-2013, 02:32 PM
loliverez loliverez is offline
Vehicle: 2013
Color: Blue
loliverez is on a distinguished road
Does an aftermarket TB void any portion of the warranty?
Old 09-06-2013, 02:46 PM
Daytona1445's Avatar
Daytona1445 Daytona1445 is offline
Vehicle: 2005 Dodge Ram
Trim Level: Daytona
Color: GoMango
Rep:12
Daytona1445 is on a distinguished road
It shouldn't but the dealer should also never even notice its there. If you are worried about it then change it back to the stock one before going in for service as it takes maybe 10 minutes to swap out.
Old 09-06-2013, 08:39 PM
HemiExpress2013 HemiExpress2013 is offline
Vehicle: 2013 Ram 1500 Express
HemiExpress2013 is on a distinguished road
I'm not sure it's worth the money you will spend. I have Moes ported 87mm on my 2013 and I'm not sure it's done much but hurt my low end performance off the line. one thing for sure, you have to port the intake manifold, which I have not done, to match the TB. If not then the intake becomes the next bottle neck. negating the benefits if any from 87mm ported 80mm. From what I have read the 80mm flows more cfm then your 5.7 can want at even 6000rpm. I have a Bully dog tuner the most you can set the rpm is 6000rpm Go with the CAI, exhaust, stall converter, and Valve body upgrades for real benefits first with a tuner. If I could do it over, I would get long tubes and muffler, Not true duels unless you are adding nitrous or supercharging, before any thought of ported TB and after a CIA. I wish I had it all figured out but engines and "reversion" can get real complex when modding your truck just my opinion..
Old 09-06-2013, 10:20 PM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:627
its a good complimenting mod.
Old 09-06-2013, 10:31 PM
Trim Level: Daytona
Color: GoMango
Rep:12
I don't have one so I could be wrong but I thought the front side was ported to 87 and the back was closer to 85 which is what the opening is on the manifold or at least is on the 3rd gen.
As for the cfm air flow the idea is really to smooth out the drivability and throttle response. There isn't going to be any huge gains in power.
Old 09-06-2013, 11:14 PM
Revel Performance's Avatar
REVEL PERFORMANCE
Vehicle: MOPAR
Rep:931
Good luck.
Thanks Grub.......
sales@revelperformance.com
Old 09-07-2013, 12:03 AM
Rep:3347
The guys at Bully's have a great product.
Firstly, you don't need to port match with any of the ported 85mm or 87mm TBs as none of them out there are ported behind the butterfly (with the exception of the Fastman 84mm true-bore), which means that the exit port diameter is still 80mm, and the truck's intake bore is actually 84mm.
When it comes to volume flow, yes the stock 80mm will support the need at high RPM, but a ported body is designed to increase intake velocity. Only a true-bore will increase volume flow.
