turning off hill start assist?? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2012 Dodge Ram Forum
Old 09-05-2013, 09:56 PM
JrFuel's Avatar
JrFuel JrFuel is offline
Vehicle: 2012 Ram 1500 ST
Color: mineral gray
JrFuel is on a distinguished road
Default turning off hill start assist??
How do I turn off the Hill Start Assist on my 2012 Ram ST??
Thanks...
Old 09-06-2013, 09:56 AM
RLM5150 RLM5150 is offline
Vehicle: 2016 2500 CrewCab
Color: Maximum Steel
Rep:14
RLM5150 is on a distinguished road
Does your ST have EVIC? I turned mine off through the EVIC menu.
Old 09-06-2013, 11:25 AM
rdsabin rdsabin is offline
Vehicle: 2012 Sport Reg Cab 4x4
Trim Level: Sport Reg Cab
Color: Mineral Gray Metallic
Rep:186
rdsabin has a spectacular aura aboutrdsabin has a spectacular aura about
Here is a quote from the 12 owners manual:
Hill Start Assist (HSA)
When on is selected, the HSA system is active. Refer to
“Electronic Brake Control System” in “Starting And
Operating” for system function and operating information.
To make your selection, press and release the
SELECT button until a check-mark appears next to the
feature showing the system has been activated or the
check-mark is removed showing the system has been
deactivated.
2012 DodgeRam 1500 4x4, 20% Tint, Running Boards, Class IV Hitch, 14" Win Muffler, Catch-Can, Tow-Hooks, LED Tailgate Bar
2008 Dodge Supe Bee, Catch Can, Backup Camera, 20% Tint all windows, CAI, AFE Filter
Old 09-06-2013, 01:19 PM
T-Bone T-Bone is offline
Vehicle: 2012 Ram 1500 RCSB
T-Bone is on a distinguished road
HSA Off
Non-EVIC Equipped Vehicles
If you wish to turn off the HSA system, follow this
procedure:
1. Start with the engine OFF, and the vehicle in PARK with the wheels straight.
2. Start the engine.
3. With the engine running and the brake applied, rotate the steering wheel 180 counterclockwise from center.
4. Press the “ESC Off” switch four times within 20 seconds. The “ESC Off Indicator Light” should appear and disappear four times.
5. Rotate the steering wheel 360 clockwise (180 clockwise from center).
6. Cycle ignition switch OFF then ON.
7. If the sequence was completed properly, the “ESC Off Indicator Light” will blink several times to confirm HSA is off.
Steps 1 through 7 must be completed within 90 seconds to turn off HSA. Repeat steps 1 through 7 to re-enable HSA functionality.
HSA is a Customer Programmable Feature on a EVIC equipped vehicle. If you wish to turn off the HSA feature, refer to “Electronic Vehicle Information Center (EVIC)/Customer Programmable Features” in “Understanding Your Instrument Panel” for further information.
Old 09-06-2013, 09:49 PM
JrFuel's Avatar
Color: mineral gray
My Ram does NOT have EVIC. Question for T-Bone... where is the ESC Off switch?
Old 09-07-2013, 10:20 AM
topgun's Avatar
topgun topgun is offline
Vehicle: 2012 Ram 2500 CC 4X4
Trim Level: Outdoorsman
Rep:86
topgun will become famous soon enough
The ESC button is to the left of the Hazard Flasher button.
Undercover SE, Corsa Cat Back, Amp Powersteps, Amp Bedstep, Bedrug, Mopar Tailgate Lock, Mopar Fold Flat Floor, Mopar Flat Rubber Splash Guards, Husky X-Act Contour Floor Mats, Cooper AT3 285/70/R17's, Moroso Catch Can
Old 09-07-2013, 08:05 PM
jp7704jp jp7704jp is offline
Rep:73
jp7704jp will become famous soon enough
T bone props to you for posting that for them. Especially since its in the manual.
Mopar Cold Air Intake, tonneau, bed liner, front and rear splash guards, custom exhaust, nerf bars
Old 09-07-2013, 08:15 PM
Rep:2929
you mean that some people actually do read the manual
i have had my Ram for 4 1/2 years & i may have read 25 pages of the 600 or 700, then my eyes glazed over
Old 09-08-2013, 05:06 PM
oldhp's Avatar
oldhp oldhp is offline
Vehicle: 2014 Express 3.6/8 speed auto
Color: WHITE
Rep:902
oldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to behold
Do all RAM trucks have this HSA? Mine does not have EVIC. My dash is tach, speedo, fuel and temp gauges. Under the radio the flasher button is in the middle, to the left is traction control and then the tow/haul. Only three marked and useable buttons.
Where the odometer is, you can select odometer, outside temp, ECO and trip mileage in the inset box. The button's on the left side of steering wheel says select and reset, which control the inset box selections. The buttons on right side of steering wheel are for the cruise control.
So..do I have it or not???
2016 Challenger R/T Hemi 6-speed.
2012 Equinox 2.4...Wife's Ride
2014 RAM 3.6/8 speed/3.55 gears........Gone.
"Life's hard, it's harder if your stupid."
How would you know?
Old 09-08-2013, 05:08 PM
Rep:73
I know right?! It is long but there are some useful things in there.
