Old 09-06-2013, 05:26 PM
2011 ASSAULT 800's Avatar
Trim Level: Quad Cab Sport
Rep:251
Default Programming heat/AC control for remote start???
When I bought the truck the sakesmen said that one feature was that you can program the truck so when it is below a certain temp outside the heat will come on, heated seat and steering wheel, when its above a certain temp the ac will come on and the vented seats when you hit the remote start. I havent spent much time thinking about it lately but with having to leave for work earlier the last few mins and the temps being near freezing this week at night I have been thinking of it,
sat in the driveway for a few mins after work today going through the settings trying to find this option and couldnt find it. please dont tell me with all this technology that this option doesnt exist?? I know I can leave the heat on or AC on to where I would like it but some days at work are 13+ hour days and the last thing I am thinking about when I get home is what the weather will be the next morning and how I am going to set up my climate control.
Old 09-06-2013, 05:35 PM
cjgerson's Avatar
cjgerson cjgerson is offline
Vehicle: 2013 RAM 1500
Trim Level: Laramie Limited
Color: Black Clear Coat
Rep:65
cjgerson will become famous soon enough
You have to leave the HVAC system on Auto. Then when you remote start the vehicle it will use the external temperature to determine if the truck needs air or heat. I will also turn on drivers side heated or vented seat and the heated steering wheel if it deems necessary. I have found the auto setting works very well and I just leave my temperature set to 65-70 degrees.
RetraxOne Tonneau cover, DeeZee tailgate assist, Line-X premium bed liner, Bed Rug Bed Mat, Freedom Tailgate seal, Cabin Air filter, aFe Magnum FORCE Air Intake System, Muffllex DOD18M, AVS Aeroskin Hood Shield, Craven Stubby Antenna, Tinted Windows, AVS In-Channel Vent-visors, AMP Research Black Bed Xtender HD, Hypertech Interceptor, E&G Classics - Polished Heavy Mesh Bumper Grille insert , Lamin-X 3rd brake and fog lights, E&G Classics Polished Heavy Mesh Bumper Grille Insert
Old 09-06-2013, 06:29 PM
CharlieL CharlieL is offline
Vehicle: 2013 Ram 4x4 Crew Cab
Rep:100
CharlieL will become famous soon enoughCharlieL will become famous soon enough
There is a setting in the EVIC just for this...you need to go to the "Auto on Comfort and Remote Start" in the settings section of the EVIC. From there, there's a selection for the seat heat/cool to turn on when you remote start. It's referred to as the "Remote Start Comfort System" on page 289 of the owners manual. Remember, tho...once you hit the "start" button, the seat heat turns off and you need to manually turn that on to keep it on.
Old 09-06-2013, 07:21 PM
Rep:251
Thanks for the responses, as the temps get/stay cool I will take note of weather the heat comes on or IF it gets warm enough I will watch for the Ac and vented seats!
Old 09-06-2013, 08:04 PM
fireman21 fireman21 is offline
Vehicle: 2013 Ram Big Horn Quad
Color: deep cherry Red
fireman21 is on a distinguished road
what about trucks with non heated seats? does it still work? thanks
Old 11-25-2013, 09:08 AM
DClig10 DClig10 is offline
Vehicle: 2009 Dodge Ram
DClig10 is on a distinguished road
After looking at this thread I went into the set up and made sure the setting was checked. My heat automaticaly comes on but the stearing wheel and heated seats does not activate. It's 20* in philly this morning so it all should have started, correct??
Old 11-25-2013, 09:11 AM
Monster5601 Monster5601 is offline
Vehicle: 13 Laramie 1500, 15 Longhorn
Color: Cherry Red
Rep:470
Monster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of light
Yes, under 40 degrees F, if enabled in the EVIC, you should see both the driver's heated seat and steering wheel heat switch LED indicators on. This applies to MY13 and 14 vehicles. I don't have any knowledge of pre-MY13 behaviors so I do not know if this applies to MY09.
Old 11-25-2013, 10:17 AM
Yeah I got nothing.... I'm sure the dealer is gonna get their moneys worth out of this one!!
Old 11-25-2013, 04:33 PM
mtnrider's Avatar
mtnrider mtnrider is offline
Vehicle: 2013 Doge Ram Power Wagon
Rep:24
mtnrider is on a distinguished road
Not to sidetrack this but has anyone noticed that when you select auto on comfort in the settings screen, then exit that screen and go back that it is no longer checked? I can't tell whether the auto on is on or off until I actually try and start the vehicle.
Old 11-25-2013, 05:39 PM
Color: Cherry Red
Rep:470
I see this same behavior on other selectable options also. I can't believe they actually release software that has every indication it was never tested.
