Ordering HID lights since the Ram headlights are worthless - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Interior and Exterior Lighting
Old 09-06-2013, 10:17 PM
skytop's Avatar
skytop skytop is offline
Vehicle: 2014 Dodge Ram
Rep:420
skytop is just really niceskytop is just really niceskytop is just really niceskytop is just really niceskytop is just really nice
Default Ordering HID lights since the Ram headlights are worthless
Oh, did I mention the Ram projector headlights produce a warm, dim yellow light that is almost worthless? There are also no cornering lamps at all. With such wonderful lighting technology available, I find it very disappointing that Ram did not even offer an optional cost HID Xenon or LED headlamp system. The headlights on the RAM are straight out of the last century antiquated, obsolete technology. In the Walmart parking lot, I had difficulty knowing if my headlight were on since the projector headlight was so dim. Yes, I tell it like it is.
The high beam sensor system however, is quite good. I am referring to the 'auto mode' switching intelligence and not the light output. If you enter a real dark roadway, the high beams are automatically turned on. Any oncoming vehicle will quickly extinguish the brights.
Old 09-06-2013, 10:35 PM
country-boy country-boy is offline
Vehicle: 2014 Ram
Rep:87
country-boy will become famous soon enough
My dad did the same with his '10 3500. He hasn't had any problems, altho I was worried about warranty issues. He loves them, and you can't deny the huge improvement.
It's on my list to do with my 2014. But I need to do a lot more research on it first.
Old 09-06-2013, 11:20 PM
Arth's Avatar
Arth Arth is offline
Vehicle: 2006 Chevrolet Avalanche
Color: Bronze Alloy Metallic
Rep:2035
I suggest if you are wanting imroved light go all the way.
Have your headlights retrofitted.
Here are the results...
Looks stock right?..
Headlights/fog:
Low's only on an incline:
Highs on the same incline:
Chrome... in moderation.
Old 09-06-2013, 11:30 PM
skytop's Avatar
Rep:420
Default Now DATS what I'm talk'n bout!!! Thanks!
Tanks ARth! Great pics and info. Where did you get them from?
Headlights/fog:
[/QUOTE]
Old 09-06-2013, 11:33 PM
Arth's Avatar
Rep:2035
You actually pull your headlights off and send them in.
I got it done through the retroshop(dot)us.
It will cost you but this has been the best investment regarding light that I have seen so far.
He drops in an FX-R HID projector that is made to handle the HID bulbs. I am running 55W 5K retrosolutions HIDS.
Old 09-07-2013, 07:52 AM
skytop's Avatar
Rep:420
As you would expect, my first question is about how long is the turn around? Driving without lights is not too cool.
When you receive the modified headlights back from the company, does everything plug directly in? Are their any modification or jumper cables that must be added? In other words, is it 'plug 'n play?'
I will contact the company on Monday. Thanks very much!
Old 09-07-2013, 08:29 AM
Monster5601 Monster5601 is offline
Vehicle: 15 Longhorn 3500
Trim Level: Longhorn
Color: Western brown
Rep:535
Monster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of light
Since you have the Laramie trim, you already have projector headlamps so you don't need to send them in. You only need to get the HID kit and harness from retro solutions.
I went with the 55 watt 4300Ks in my Laramie.
2013 RAM 1500 CC Hemi Laramie 4x4 in Cherry Red
2015 RAM 3500 CC CTD Longhorn 4x4 SRW in Western Brown
Old 09-07-2013, 08:42 AM
Arth's Avatar
Rep:2035
This is where the retroshop differs. You just put HID's into your halogen-projector. While the output is better...it isn't the best.
Here is the comparison.
Stock Projector with 55W 5K HID's:
Retrofitted headlights, same HIDS:
If you want an easy fix.. dropping in HID's is fine. If you want performance the retrofit is the only way to go. Turning on my fog lights is just overkill.
Sky-- The retrofit will still allow you to keep your headlights plug and play. HID's however are plug and play to an extent. If you choose to get a retrofit done and buy HID's from the retroshop JJ will get the headlight housing all set up.
You will have to wire/setup the relay harness as well as mount the ballasts for the HID's. The overall system is basically plug and play with a little bit of creativeness required to make it look factory.
Old 09-07-2013, 09:13 AM
Rep:535
Wow, didn't realize there was a difference in projectors, thanks for the comparison photos. So now I ask, as did someone else, how long does it take to get the headlamps reworked with the new projectors?
Old 09-07-2013, 09:41 AM
Vehicle: 2014 Ram
Rep:87
I'm very surprised about the difference too. I'd like more solid information on what retroshop did specifically. Still looks like the same 70mm housing. The two pictures you showed (both with HID but different housings) just doesn't make sense. You certainly have my attention. I trust you - but still want the full story.
Monster - Did you do this in 2014? Did you replace with the 9012/HIR2 lamps only (the ones that handle BOTH low/high beams, or did you replace the additional highbeams with 9005/HB3 too?
