Old 09-07-2013, 03:23 PM
birdistheword's Avatar
birdistheword birdistheword is offline
Vehicle: 1972 Chevy K10
birdistheword is on a distinguished road
Default 98 Ram 1500 4x4 vibration
Hello all. I'm personally a 67-72 GM truck guy but my friend needs help with his truck. It's a 1998 Ram 1500 4x4 V8 auto. He has a bad vibration once he is going 40 and above. He just replaced his transfer case cause it was cracked bad enough to leak all the fluid out of it. That helped out to get rid of some of the vibration but it's still pretty bad. Could it be a transmission problem? The truck is lifted a bit and has 35's. Thanks for any help.
Old 09-07-2013, 06:13 PM
dodgeman1821's Avatar
dodgeman1821 dodgeman1821 is offline
Vehicle: 2010 dodge ram trx4
Trim Level: Trx4 standard cab
Color: deepwater blue over graphite
dodgeman1821 is on a distinguished road
ujoint up cloise to tranny is bad , it may not look like it but i had to change one twice because even the new one was bad. or he may have lost a driveshaft weight, and is out of balance
Old 09-09-2013, 10:33 AM
Wh1t3nukle's Avatar
Wh1t3nukle Wh1t3nukle is offline
Vehicle: 2000 Ram ORE 4x4 5.9L
Trim Level: Laramie SLT
Rep:55
Wh1t3nukle will become famous soon enough
Need more information.
When did the vibe actually start? After the lift? After some other mod? It seems it was definitely present before the tcase swap.
Most typical vibes at that speed are related to angle of tcase and rear axle pinion going out of spec.
00 Ram 1-ton ORE; 3" BL; 14" coilovers; ARBs, 37" Toyos; R/T Camshaft; Mopar M1; Custom long arms, sliders and bumpers; 12K Winch; York +5g OBA
Old 09-11-2013, 10:19 AM
Astartes Astartes is offline
Vehicle: 2010 4.7l v8 4x4
Rep:160
Astartes has a spectacular aura aboutAstartes has a spectacular aura about
This happened to my friends jeep. Then the drive shaft fell off
Greater love has no one than this, that a man lay down his life for his brothers. -John 15:13
My Mods
