Old 09-07-2013, 04:45 PM
MitchellBoyz's Avatar
MitchellBoyz MitchellBoyz is offline
Vehicle: 2013 Ram 1500 Express
Color: Bright white.
Rep:33
MitchellBoyz is on a distinguished road
Default Help :( I pulled the wrong fuse.
Hi i recently bought a 2013 ram express crew cab. Loving the truck.
I went to the track and a friend of mine told me that pulling the F06 Fuse will disable traction and give me a unrestricted launch and help me achieve better times.
So i pulled the fuse and ran a 15.6 which isn't bad. But i installed the fuse back in the truck and now i have a abs, a traction light, and a service abs message on my dash. Its saturday and the service dept. is closed.
How do i fix my truck is there a reset i can do or something? no matter what i do my light is still on.
2013 Bright white Express crew 4x2, AKA Stormtrooper
Old 09-07-2013, 04:48 PM
gopackgo69's Avatar
gopackgo69 gopackgo69 is offline
Vehicle: 2014 Ram 1500
Rep:20
gopackgo69 is on a distinguished road
Next time pull the 1d10t fuse
2014 4x4 Hemi sport , 3.92, Pro-comp level 2.75", Rear Fox 2.0, 1.5" springs, Diablo 93 Tuned. Toyo AT2 295/65/20
fishin4ladyz fishin4ladyz is offline
Vehicle: 2013 RAM1500 QUAD 4x4 3.21rear
Trim Level: tradesman
Rep:14
fishin4ladyz is on a distinguished road
did you try unhooking the battery for a while?
Old 09-07-2013, 04:51 PM
DarthRam's Avatar
DarthRam DarthRam is offline
Join the Dark Ram Side!
Rep:1543
Try unhooking the negative battery terminal and let it sit for two hours. Whatever you do, if you bring the truck in to the dealer, do not tell them about drag racing. I know it is a no brainer but some dealer service departments can be d-bags.
Old 09-07-2013, 05:19 PM
Rep:33
i unhooked the entire battery both negative and positive i'm going to let it sit for 2 hours. Is there any other solutions? will this be under warranty?
Old 09-07-2013, 05:38 PM
Brandon .30-06 Brandon .30-06 is offline
Rep:29
Brandon .30-06 is on a distinguished road
Yes it could be warranty. I would try unhooking your battery to see if it clears the code. Pulling that fuse can result in the computer thinking it lost communication with the modules therefore triggering a CEL. In future it's probably be best not to pull the fuse as the dealer may catch onto what is going on and that means ITS CP and the old phrase of "put it in the bum" comes into play
I would personally not charge to clear the CEL but I can't say that all mechanics are as generous as me.
Brandon
Level 4 Chrysler tech
Old 09-07-2013, 06:01 PM
Rep:33
Brandon
I don't have a check engine light, Just a ABS and Traction light.
Old 09-07-2013, 09:30 PM
Rep:33
Guys i tryed discoing the battery for 3 hours. Didnt work. Is there any other kind of way to reset the computer? If i take this in the service dept and just tell them i pulled the wrong fuse do you think they will void my warranty? Or charge me for it (esc)
I need advice how to go to the service dept and ask them to fix it. What should i expect its my first new car
Also are service. Departments open on sundays?
Old 09-07-2013, 09:37 PM
Chunkem's Avatar
Chunkem Chunkem is offline
"Just living the dream"
Trim Level: Longhorn Rambox
Rep:1637
I would try and disconnect the negative on the battery terminal...If that doesn't work I would take it to the dealer.....Let us know how you make out.....
Old 09-07-2013, 09:47 PM
maw76's Avatar
maw76 maw76 is offline
Vehicle: 2013 RAM 1500 QC
Trim Level: Outdoorsman
Rep:49
maw76 is on a distinguished road
might reset after a couple of cycles, i.e. cold start and up to running temp and then the ecu will say must of been a glitch. On top of pulling the cables off the battery you can take the neg & pos cables touch them together when removed to ensure that there is no juice left in the system or remove and turn ignition on to ensure that there is no juice in the system.
