Old 09-07-2013, 08:18 PM
Denise63 Denise63 is offline
Vehicle: 2013 Dodge Ram 1500
Denise63 is on a distinguished road
Default offset question
Hi everyone! Newbie here and I am hoping someone can help me out I have a '13 ram 1500 sport with NO leveling kit or lift. I am wanting new rims and have found some with a -12 offset. The backspacing is 4.53 I believe. I have 275/70R18 tires I need to use. I would like them to stick out a little more than the factory wheels/tires, but I have to be careful because I drive on gravel everyday. I have been told by some tire shops that this won't work and others say it will be fine. I don't know what answer is correct
Thanks in advance for any help!
Denise
Old 09-07-2013, 10:46 PM
brandonjansen's Avatar
Trim Level: Laramie Limited
Rep:2067
Those tires are only 33.2"x10.8" which is only slightly larger than stock. You'll be able to fit those no problem on an 18x9 -12 offset rim. Keep in mind that they will be sticking out over an inch further than the stock wheel/tire set up.
Old 09-07-2013, 10:50 PM
LowUFO's Avatar
LowUFO LowUFO is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Sport Crew
Color: True Blue Pearl
Rep:1123
Your new rims will sit 31mm further out than stock 20" rims. No issue other than rocks being thrown onto the side of the truck.
R.I.P. MOPAR BIG HORN (KYLE)
Old 09-07-2013, 11:14 PM
Thanks for the help!
Old 09-09-2013, 01:01 AM
fastNugly @ RP's Avatar
Revel Performance
Rep:1804
Both answered it
sales@revelperformance.com
