Old 09-08-2013, 07:48 AM
TTaylor34 TTaylor34 is offline
Vehicle: 2013 Dodge Ram 1500
TTaylor34 is on a distinguished road
Default Undercoating and lifting/leveling?
I have a 13 Ram Sport and am ready to pull the trigger on a lift, the last problem i am down to is that i live in Western NY. Seeing how they salt the roads uncontrollably in the winter, i feel undercoating my truck is a must. Otherwise my new ram is a rust bucket within a few years.
My plan was level with bilsteins and a coil spacer then add my wheels and tires and drive it for a while (still undecided on what lift i want)
I could just level and lift before get it undercoated, but how i don't know how hard it would be to change things if i was unhappy with the lift.
Has anyone else had any experience with this?
Any help is much appreciated! thanks!
Old 09-08-2013, 11:58 AM
BuckWild09's Avatar
BuckWild09 BuckWild09 is offline
Vehicle: 2007 Dodge Ram 1500 Hemi 4x4
Rep:63
BuckWild09 will become famous soon enough
I live in Ohio where we salt our roads pretty hard too. Id tell you to take off every bolt you can and coat it with never-seize. I have an 07 Ram and bolts were already siezed and had to cut alot of stuff out!
I undercoated my truck myself with the rubberized spray you can get from autozone. The Bilsteins will level the truck by themselves. How big of a lift are you looking at? What are your goals(tires/wheels)? You wouldnt want to spend money on tires then lift the truck.. unless your just going with a level. tires will end up looking small imo
3" Zone Body Lift--6" RCX-- Bils @ .5"-- 20x12 Fuel Hostages--37x13.5" Toyo MT
Old 09-08-2013, 06:46 PM
I want was looking into a 4" lift, then swapping my stock 20" wheels for 18" to fit more rubber. Probably 33" tires. I have seen trucks leveled with a coil spacer that look like a 4" lift so i wanted to start there and see how much more i wanted to add. But if i do this then undercoat it, i don't know how difficult it would make it to add the lift later on.
Old 09-08-2013, 08:13 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2036
Most under coatings don't typically cover any of the suspension parts. Just the body parts and frame. So typically all the bolts for anything to do with suspension should be free and easy to access if you want to lift it down the road.
When you do buy a lift be sure to go through all the parts and make sure all of them are covered properly in paint or powder coat. Then you should be good to go.
