Old 09-08-2013, 12:51 PM
just2grand just2grand is offline
Vehicle: 2013 Ram Laramie Quad Cab
Color: Deep Cherry Red
just2grand is on a distinguished road
Default gforce chip
Hi, I have a 2013 laramie and bought this performane chip.Has anyone installed this in there truck of the same year, if so which two wires do you use.. I could'nt figure it out. Thanks for the help.
Paul
Old 09-08-2013, 01:39 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
I would put that thing back in the box and return it. they are a huge joke. they don't do a dang thing for your truck.
you want a real tuner/programmer
Old 09-08-2013, 02:24 PM
Asur Asur is offline
Vehicle: .
Rep:4373
Wow, ok, first thing, don't install this thing, second thing, seriously don't install it and send it back like gonefishin said, third, if you still want to install it, connect the first wire to the second wire, use tape if needed, then hold it about 3 ft off the top of a garbage bin and then open hand, if it stays stuck to your hand try and wiggle it a bit to loosen it, If you still can seem to get it to work for what it was intended for, move hand towards bin in a fast movement and then halt above the can it should come loose and start flying.
Old 09-08-2013, 05:13 PM
Monster5601 Monster5601 is offline
Vehicle: 13 Laramie 1500, 15 Longhorn
Trim Level: Longhorn
Color: Western brown
Rep:476
Monster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of light
Like the others have said, send it back, pronto.
All it does it tell the engine controller that the air temperature coming in to the engine is cooler than what it really is.
2013 RAM 1500 CC Hemi Laramie 4x4 in Cherry Red
2015 RAM 3500 CC CTD Longhorn 4x4 SRW in Western Brown
