Old 09-26-2013, 11:55 PM
I push the skinny pedal
Rep:3277
As I said there's a place for them, and I only lump them together with other CAIs when comparing them to real performance systems designed to optimize flow velocities, and sadly none exist for the Ram without modifications.
Kurtis
Old 09-27-2013, 10:22 PM
05ram's Avatar
05ram 05ram is offline
Vehicle: 2004 Dodge Ram SRT10 RC 6spd
Trim Level: SRT10 RC
Color: Brilliant black
Rep:145
05ram will become famous soon enough05ram will become famous soon enough
I wish S&B made one for my SRT10, that being said, in the case of the Viper truck the OE CAI with a K&N drop in made the same and in a few instances more HP than all the available aftermarket CAI's made, great design from the factory. So in some cases the OE setup is better than aftermarket ones. This only relates to the SRT10 truck though. If I had a Hemi RAM again it would get the S&B hands down........
Traded in[SIGPIC]2004 SRT10 RC in black, with 500+HP, B&G Stage2 PCM, K&N drop in, JMB Catless mids, JTSVP Gen1 shifter, all synthetic fluids, lots of underhood billet with a Snakeskin radiator cover from JTSHydro, LED tails, BedRug, colormatched tonneau!!!!!!!! Upgraded!!!!!!!!
Old 10-02-2013, 04:13 PM
brondondolon's Avatar
brondondolon brondondolon is offline
Vehicle: 2009 Dodge Ram 5.7L hemi
Trim Level: 1500
Rep:177
brondondolon has a spectacular aura aboutbrondondolon has a spectacular aura about
i have the S&B and i wish i got the Vararam intake only because the way it looks. I dont think you can go wrong with either brand though. The difference in power gains between Vararam and the S&B wouldnt even be noticeable id imagine. So id say buy which ever one you think looks better to you. Also one thing to consider is the S&B is in a closed box where the Vararam is some what open. So the Vararam id imagine will give you more of an aftermarket intake sound which i dont hear with my S&B unless i floor it up hill.
S&B CAI, Y-pipe muffler delete, Diablo intune, Hemifever, custom tune, 180 thermostat, BT oil catch can, smoked, tail light and 3rd breaklight, 5000k retrosolutions 55w HID headlights and fog lights, LED in all exterior lamps, red calipers. Future mods: 87mm TB, 3000 stall torque converter
Old 10-03-2013, 01:34 AM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
Actually almost opposite from what would think until they have ran one, the Vararam is relatively quite, and not much louder than stock at all.
Old 10-03-2013, 05:52 PM
Droptop87's Avatar
Droptop87 Droptop87 is offline
Vehicle: 2014 Dodge Ram
Rep:40
Droptop87 is on a distinguished road
I went with the SB quality is perfect looks great sounds great. I even ran it with the plexiglass cover and found no difference in sound quality at all so I put it back on I know maybe its my ears but with my cat back and this it seems much more responsive and really sings over 4 grand
Old 10-14-2013, 04:58 PM
deekum1627 deekum1627 is offline
Vehicle: 2012 Ram 1500 Crew Cab 4x2
deekum1627 is on a distinguished road
how much bigger is the S&B over the stock box??
Flowmaster 40 series muffler with reso delete and Flowmaster tips/ bakflip cover/ AMP bed extender/ 3.92 gears/ 8k hids/ BT catch can/ S&B cai/ vleds fogs/ paramount bumper grille
Old 10-14-2013, 06:20 PM
Grubrunner's Avatar
Rep:3883
It's a little bigger with a slightly different location.
It's tucked up closer to the firewall than the OEM.
Looks a lot better.
Grub out!
Old 10-15-2013, 03:22 AM
Looks a lot better.
thanks. im gonna be ordering mine when i wake up cant wait. i hope to get it by the weekend so i can install it
Old 01-13-2014, 08:27 PM
RAMESPY24's Avatar
RAMESPY24 RAMESPY24 is offline
Vehicle: 2014 dodge ram
RAMESPY24 is on a distinguished road
Originally Posted by Bully's Performance View Post
Both are great Units! However in all honestly I have found a new intake that I am starting to prefer more and more, there are only a couple people here on the Z running them, and they are not talked about that much (mainly known over in the Challenger/Charger/300 side of the Z however Leg Maker Intakes makes one of the highest quality CAI's I have ever seen and they are priced very reasonable for being actual Carbon Fiber!
OH FORGOT TO MENTION, the filter they use is an S&B filter so you are getting top notch filter match with top notch craftsmanship can't go wrong
The CAI I am talking about is the LMI feel free to check them out here is a couple pics. Each unit is hand crafted from raw carbon fiber!
(don't mean to mix it up just have to let everyone know of other options, of coarse the Vararam and S&B are still excellent products you can check out the Vararam's here http://bullysperformance.com/vararam...rucks-126.html)
Full Leg Maker Intake Line
Dodge RAM Leg Maker Intakes
LMI MID Tube CAI (09-13) 5.7
This Natural CARBON FIBER intake tube will fit all 5.7L Dodge Ram Hemi's from 2009-2012. The LMI MID Tube CAI (09-13) 5.7 utilizes the factory airbox so you can maintain a sealed air intake, It replaces the restrictive factory intake tube with a 4" Carbon Fiber replacement.
This kit Includes:
LMI Carbon fiber intake tune
clamps
couplers
18" IAT extension harness to relocate the IAT sensor into the intake flange of the OEM airbox.
The factory engine cover will work with this intake!
LMI Short Ram CAI (09-13) 5.7
o Carbon Fiber construction
o Unique fabrication process resulting in smooth inner surface to ensure smooth airflow
o 4” diameter carbon fiber tube with 45* bend to allow for placement of filter over air intake opening in fender well
o S&B Filter with 8 layer protection (oil type)
o Hi-temp rubber coupler
o High quality “T”-bolt band clamps
o Available to fit both stock and 90mm throttle bodies
o Drilled for IAT sensor
o Oil breather filter (red,blue,silver)
o All necessary hardware and instruction for DIY installation
and of coarse a review from one of our fellow Z members
Thanks for the read (sorry for the sales not generally my style but this is truly a product to be considered and everyone should know )
Jeremiah
Hi Jeremiah,
I installed the Leg Maker short ram intake last night and I must say that I did feel a big difference in throttle response. I like the way it looks however, I could not get it to fit right without removing the engine cover and keeping it off. Is it suppose to fit without the cover?
LMI Short Ram Intake, Diablo Sport Trinity 93 tune, Retrax Pro Cover, Stubby Antenna, Deeze Tailgate Assist and Moroso Gloss Black Oil Catch Can, tint, and blacked out emblems. Soon to come Spintech 6000 pro street muffler with Flowmaster Y-pipe and Fastmann TB with Hemifever Tune.
Old 01-13-2014, 09:20 PM
Jayincali's Avatar
Jayincali Jayincali is offline
Vehicle: 2014 Dodge Ram 8 Speed 3.92
Color: Deep Cherry Red Crystal Peral
Rep:95
Jayincali will become famous soon enough
I would like the leg maker more if the filter was dropped down a bit more, similar to how the AEM Brute Force was on the 3rd gens.
