Old 09-10-2013, 12:58 PM
mineralram's Avatar
mineralram mineralram is offline
Vehicle: 2015 Dodge Ram
Rep:166
mineralram has a spectacular aura aboutmineralram has a spectacular aura about
Default Black door divider stickers
Anybody have a silver ram with the door divider stickers removed
Old 09-10-2013, 01:02 PM
Rep:2051
I'm assuming you mean the B-pillar tape.... I have a mineral grey Ram with them removed... not exactly silver but it will give you an idea of what it will look like.
Before:
After:
You will definitely not regret taking it off. Looks so much better without it. Even more so in person.
Old 09-10-2013, 01:18 PM
Iqudayo's Avatar
Iqudayo Iqudayo is offline
Color: Mineral Gray Metallic
Rep:563
Looks so sexy !!!!!!!!!!!
Old 09-10-2013, 04:17 PM
Big Red 1 Big Red 1 is offline
Vehicle: 2014 Ram
Trim Level: Sport Crew Cab
Rep:20
Big Red 1 is on a distinguished road
How difficult was it to remove the tape? Did you have to use a heat gun or just gently pull? I had a 2001 Ram and one of the bed rail caps had to be replaced. They were secured with 3M tape and when the cap was removed; so did the paint. I almost freaked out! Fortunately, I replaced them with warranty issued parts. Hopefully the paint on the new Rams is bonded better than the old.
Old 09-10-2013, 05:39 PM
arietem's Avatar
arietem arietem is offline
Vehicle: 2013 Dodge Ram 1500 4x4 QCab
Trim Level: SLT - 8spd 3.55 20"
Color: Mineral Gray Metallic Clear
Rep:368
arietem is just really nicearietem is just really nicearietem is just really nicearietem is just really nice
Hi all, try this link ..
http://www.ramforumz.com/showthread....ht=pillar+tape
Regards
Old 09-10-2013, 07:20 PM
Rep:2051
It's definitely a little hard on the fingers. But I didn't use any heat gun or anything like that. I just started on the top corner opposite the window and pulled that whole edge out towards the outside of the door. Then start pulling down from the top at a 45 degree angle towards the window (it makes it a lot easier to get the edge inside the window off) and just work your way down.
Once you have the vinyl off completely you just have to work the glue residue off. I used WD-40 and a terry towel. Took some elbow grease but I got all 4 done in about half an hour. Definitely worth the time and work.
Old 09-10-2013, 07:52 PM
mineralram's Avatar
Rep:166
I just removed the stickers from all 4 doors took about 10 minutes they peeled off clean no residue
Old 09-10-2013, 08:12 PM
ILuvaMyTrucka's Avatar
ILuvaMyTrucka ILuvaMyTrucka is offline
Vehicle: 2014 Ram 1500 4x4 CC
Color: Maximum Steel Metallic
Rep:38
ILuvaMyTrucka is on a distinguished road
Ya mine came off with no residue as well.
Lets see a pic of the truck with them off.
Current: BakFlip FiberMax, Pillar Tape Removed, Partial Debadge (moved hemi badge to tailgate), Tinted Fronts to Match Rears (15%)
Future: TBD
Old 09-10-2013, 08:30 PM
Whiplash's Avatar
Whiplash Whiplash is offline
Vehicle: 2013 1500 SLT Big Horn 4x4
Color: Black Gold
Rep:177
Whiplash has a spectacular aura aboutWhiplash has a spectacular aura about
same with my 11, no crap to work off...
tho there was the tiniest little piece of "tape" right at the bottom edge i never could dig out
imo, any color it's def. worth the time to remove it
do it soon tho, you want the whole truck to react to the elements equally....
MODS: Magnaflow 16869 cat-back - S&B CAI - BakFlipG2 - Bilstein 5100s F/B - AirLift 1000 - BackRack - FT-857D/ATAS-120
next: Rims 'n rubber - That'll be it, too many electrical risks involved to go furthur
Old 09-10-2013, 09:32 PM
Chunkem's Avatar
Chunkem Chunkem is offline
"Just living the dream"
Trim Level: Longhorn Rambox
Rep:1637
I have left mine on, but man does it look good removed......
