Old 09-09-2013, 03:08 PM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
Default LED Bed Lighting
So I know this has been done before but I wanted to show how I did my LED bed lighting.
I can now press the remote unlock button on my key-fob or press the rear bed light switch on the dash and the lights will come on in the truck bed.
Parts needed:
1, Roll of Bright White 5050 SMD LED Strip Lights 16'-4" long with 300 LED lights and waterproof.
1, Roll of 3M double sided tape 16 feet long.
1, 30 amp relay with relay plug harness.
1, 7.5 amp fused 16 gauge wire 2' long.
1, Ground wire 16 gauge 1 foot long.
1, 20 foot long 16 gauge wire.
1, 6 foot long 16 gauge trigger wire.
1, T-Tap connector.
6, Butt connectors.
Total cost around $45 for parts.
Total install time 4 hours. I work slow!
I first started off with a 7.5 amp fused wire, a 30 amp relay, and relay plug. (picture 1)
Then I went and found the white with brown stripe wire located at the drivers side wiring harness under the kick plate. (picture 2)
I tapped into that wire and ran a trigger wire to the relay plug under the hood. (picture 3)
Under the hood I attached the trigger wire from the drivers side kick plate, the ground wire from the battery, the hot wire with the 7.5 amp fuse from the battery/fuse box terminal, and the wire to the LED bed lights to the relay plug. Next I plugged the relay into the wiring plug. (picture 4)
I ran the wire from the relay to the rear drivers side taillight where I attached it to the LED strip lights. I also attached a ground wire from the LED strip lights to the body behind the taillight with a sheet metal screw.
I ran 3M double sided tape around the inside of the truck bed and attached the LED strip lights. (pictures 5 & 6)
The LED strip of lights starts at the hole next to the drivers side taillight and goes all the way around the inside of the truck bed to the passengers side taillight. I used all 16'-4" of LED lights. That is 300 LED lights! I had about 6" of extra LED lights which I just tucked in behind the passenger taillight.
The 5050 SMD LED lights are very bright and require about 7 amps of power to light-up. So you need to run a 7.5 amp fuse and a relay for this many LED lights. Do not just tap into the OEM wiring harness for power, use a fuse and a relay.
I hope you find my bed light installation interesting and different. If you have any questions just ask.
Greg
2013 Outdoorsman CC.
Pentastar V6, 3.55 LSD
Lots of mods
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 09-09-2013, 03:13 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
I did mine pretty much the same way except I went with a dark blue glowing effect. Here's some reps for the how to, nice job. Here is what mine look like, http://www.ramforumz.com/showthread.php?t=82115
Old 09-09-2013, 04:02 PM
RogerRamJet's Avatar
God Bless Texas!
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
Very nice job, Greg. Reps for the show & tell.
Old 09-09-2013, 10:36 PM
DatacomGuy DatacomGuy is offline
Vehicle: 2013 Dodge Ram
Color: Mineral Gray
DatacomGuy is on a distinguished road
Was just about to start this project. Thank you for posting!
2013 1500 CC | Mineral Gray | Hemi 5.7 | 3.55 LSD | 15% | Dip'd Badges | 4" AirBox CAI | Cut Antenna
Old 09-10-2013, 12:12 AM
Thebestestdrummer's Avatar
Vehicle: 2001 Dodge Ram Sport
Rep:529
what is that piece that you tapped into the wire with called? Ive been seeing them all over the forum but i cant seem to find any anywhere!
Green Interior LEDs
Old 09-10-2013, 09:16 AM
gcscott's Avatar
Rep:1043
If you are talking about (picture 3) that is called a T-TAP self taping wire connection. It wraps around the wire, then you squeeze closed the one part, then you attach a standard male wire terminal that holds it together. I use them all the time when I need to tap a wire without cutting the wire.
You can get them from Radio Shack or some auto parts stores. They come in 3 different sizes. I use the blue ones for 14-18 gauge wire.
http://www.radioshack.com/product/in...tent=CT2032231
I would only use them inside the truck or you can use some dialectic grease to keep out moisture.
Old 09-10-2013, 09:45 AM
Asur Asur is offline
Vehicle: .
Rep:4373
Nice job, reps for the write up
Old 09-10-2013, 09:34 PM
Rep:529
Thank you very much! haha
Green Interior LEDs
Old 09-20-2013, 03:01 PM
Socalgordon Socalgordon is offline
Vehicle: 2014 Dodge Ram 1500
Trim Level: Big Horn Crew Cab
Rep:126
Socalgordon will become famous soon enoughSocalgordon will become famous soon enough
why not tap into the OEM wiring harness for power? why use a fuse and a relay? Is it because of the amps the leds are pulling? If I used leds that pulled only 3 amps, would I still need a fuse and relay?
Old 09-20-2013, 03:25 PM
Stump3r's Avatar
Stump3r Stump3r is offline
Rep:1266
Here is how I did mine, and they are wired into the dome circuit. I don't remember the exact figure mine pull but I haven't had an issue with blowing fuses or overloading circuits.
Big Red my old 2011 Sport
