Old 09-09-2013, 04:41 PM
squig69 squig69 is offline
Vehicle: 15 quad cab
Trim Level: sxt
Color: granite metallic crystal
Rep:13
squig69 is on a distinguished road
Default reversing with surge brakes locking up
ive got a boat and trailer with surge breaks and every time I reverse on any kind of slight incline the brakes engage on the trailer. trailer has the 5pin connector and ive got a 5into7 adaptor for hooking up to the truck and when I put it in reverse its suppose to either engage or disengage the brake selinoid so you can revese without the trailer brakes engaging. someone mentioned that the fuse on the truck might be no good but when I looked at the fuse panel and the diagram it shows that there are either 2 or 3 fuses for trailers? don't know which one to look for and check. all lights work on truck and trailer but the trailer brakes keep me from backing up . can someone point me in the right direction.
thanks
things out of square make me cry
Old 09-09-2013, 04:47 PM
APSTRAM's Avatar
APSTRAM APSTRAM is offline
Vehicle: 2012 Ram 2500 Crew Cab 4x4
Color: Deep Cherry Red
Rep:85
APSTRAM will become famous soon enough
Surge brakes are not the same as the electric brakes the surge functions with the weight of the trailer pushing on the master cylinder of the surge brakes when stopping, when you back up an incline the weight of the trailer does the same thing and engages the brakes. There is usually a pin you can install that defeats the brakes mechanically and allows you to back up an incline.
Old 09-10-2013, 03:09 AM
Dak2 Dak2 is offline
Vehicle: 2011 RAM 1500 QUAD CAB 4X4
Dak2 is on a distinguished road
It should be the center pin of the 7way connector on the truck. The center pin is for backup lights or the solenoid for the surge brakes if the trailer is equipped with solenoid release.
Don
Old 09-10-2013, 03:32 AM
Rep:2657
For years i pulled trailers with Surge Brakes
if you don't have a place to put a pin in to keep the surge part of the braking system from moving toward the ball hitch
you have a few choices,
drill a couple holes through the trailer hitch, so that you can put a pin through & stop the movement while backing up
or cut a 2x4 down to shove in that sliding piece when you need to back up
or do what we did
we found a piece of angle iron, cut it to about 6" long, welded a short piece of light chain to the angle iron & some part on the trailer near the sliding part
When you are ready to back up, insert the blocking device of your choice, & back up the incline
the nice part of using the angle iron, when you pull forward, the angle iron will vibrate out & hang on the chain
simple but effective
Old 09-10-2013, 07:17 AM
Trim Level: sxt
Rep:13
Don
trailer has the solenoid to deactivate the brakes when the reverse lights come on and ive also got the pin to insert into the coupler to stop it from compressing the master cylinder on the trailer. read somewhere that there is a fuse in the truck that might have to be replaced so that when the reverse lights come on it activates the solenoid so the trailer brakes don't engage. I wanted to check the fuses first before I contact the trailer mfg incase the solenoid is defective
thanks for the help guys
Old 09-10-2013, 08:14 AM
No fuse that I'm aware of. It is the same circuit as your backup lights on the truck, so if your backup lights work so should your trailer.
Don
Old 09-10-2013, 01:47 PM
Trim Level: sxt
Rep:13
Don
thanks, that's what I was wondering about, all lights are working so gonna contact the trailer mfg
thanks again for the help
Old 09-12-2013, 02:13 PM
lewisb13 lewisb13 is offline
Vehicle: 2011 Dodge Ram 1500 Big Horn
Rep:19
lewisb13 is on a distinguished road
Put your truck in reverse and see if you are getting voltage at the solenoid. If you ARE then the solenoid is bad, if you are NOT, then its time to start working backwards starting with your adapter, then the bumper plug itself, etc etc.
