Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Diablo Predator Questions & Info!
Old 09-14-2013, 10:45 PM
09HemiCrew 09HemiCrew is offline
Vehicle: 2009 Dodge Ram
Rep:75
09HemiCrew will become famous soon enough
Thanks for the feedback guys. I've been running on the stock tune and watching my knock values. I'm having some ST retard issues mostly at part throttle (sometimes 4deg+). I've ran multiple injector cleaners through it, sucked a bottle of sea foam into the intake, fresh NGK's, can't seem to get it with simple solutions. Anyone have any other ideas? Im running 89 octane fuel from good gas stations. Is this normal or do I have issues? I'm going to take a look in my intake manifold and see if it is full of oil and maybe a catch can would help me out. I'm thinking this knock issue is making the dsp tunes seem worse than they are.
2009 Crew Cab 4x4 Laramie - 4.56 gears, Detroit Truetrac, Diablosport Trinity
Old 09-14-2013, 10:52 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
The pcm retarding timing will result in power loss. What tune are you running with the 89 octane? 89 tune? 87 tune? If it's an 89 or 87 tune and you're using 89 octane you shouldn't have any issues. Try some 91 or 93 just to see if you notice a difference and if it stops from pulling timing.
4 deg may not be a big deal especially if not at wide open throttle and high rpm. I've seen as much as 9 deg pulled on the superchips 93 tune with 93 octane. Depends on a lot of things. Temperature can have an impact. The biggest factor is weight of the vehicle(load on the engine). The more load, the more chance of detonation. That's why you can't tow/haul with the performance tunes unless you use higher octane.
Sean
Old 09-14-2013, 11:00 PM
Arth's Avatar
Arth Arth is offline
Color: Deep Cherry Red Crystal Pearlcoat
Rep:2035
I will say I hated the canned tunes. No matter how I ran it i always got to much knock st or lt. I always run 93 octane gas when I can get it by the way.
Once I got my custom Hemifever tune there were a few major improvements over the canned tunes. The most important being the knock degrees.
I see 0 LT knock and a max of 2 degrees of ST knock when I tow.
I refuse to ever run the canned tunes again as long as I can have custom tuning.
Chrome... in moderation.
Old 09-15-2013, 12:05 AM
Asur Asur is offline
Vehicle: .
Rep:4373
Originally Posted by Grubrunner View Post
Damn Asur, you've been playing us all this time?
Does this mean I need to sell my truck for a 5.7 just to be none BS? what to do?, what to do? All those mods
Old 09-15-2013, 04:12 AM
RogerRamJet's Avatar
I do it because I can!
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
Ah, the line starts right here, behind me, for that truck!
Old 09-15-2013, 12:36 PM
Buellrider's Avatar
Buellrider Buellrider is offline
Vehicle: 2012 ram 1500 R/T
Trim Level: R/t
Color: Wht
Rep:145
Buellrider will become famous soon enoughBuellrider will become famous soon enough
I have hemifever v1 89 and 91 tune and v2 and 89, 91 and all of my quickest passes are on the diablosport 91 tune....
2012 R/T
Old 09-16-2013, 04:21 PM
BlackRamHemi's Avatar
Vehicle: 2010 Ram RCSB 4x4
Rep:561
The OP has an 09' Hemi Ram, and there is just no way a BullyDog tuner is superior on that year and model. period.
The highest possible shift points on a Bully Dog are 5900 rpm and their highest available octane tune is a 91+
Diablo can increase throttle sensitivity/response by 20%, shift at over 6200 rpm and the highest available tune is 93 octane,
it also offers a 100% traction control disable feature in addition to Data logging capability.
...and those are the reasons I went from 14.3 to 13.8 in the quarter, both canned tunes (no custom)
If the OP was having issues, it could have been poor fuel, not high enough octane (I never run lower than 89 on a Hemi)
But at least with a Diablo tuner you can data log for LT/ST Knock Retard to see if its a fuel related issue and not the tuning.
If you're getting knock due to lower octane fuel, the PCM will retard your timing and it will feel sluggish regardless of which tuner you use.
Great info and very good to have, but it is still only a 2 truck minority to that of the quantity out there.
I'm a member on at least 5 different Ram forums, some of them since 2004,
in going on four years, I have yet to see anyone post a 13 second time slip with a Bully Dog Tuner on a 4G Ram.
Dating way back to long before "Custom Tuning" was even being utilized by any 4G Ram owners.
But don't take my word for it, I beg you....please go visit a few forums and see it for yourself.
They all have a Performance Section with an Official Time Slip thread. Proof Required to make your claims.
Almost all members list their gear in their sig lines...Now YOU tell me which tuner is in the Minority. 2 truck minority pfffft!
If Bully Dog is so much better at performance tuning, and so dominant, then where are the ALL the time slips?
Put the BS opinions aside and show me some numbers from people that actually run their Trucks, not just their Mouths.
Opinions are like @ssholes,
Show me the Numbers!
Challenge issued!
let the back-pedaling begin!
Old 09-16-2013, 06:15 PM
Vehicle: .
Rep:4373
The highest possible shift points on a Bully Dog are 5900 rpm and their highest available octane tune (91+)
Diablo can increase throttle booster (sensitivity/response) by 20%, shift at over 6200 rpm and highest available tune is 93 octane, 100% traction control disable feature.
If the OP was having issues, it could have been poor fuel, not high enough octane (I never run lower than 89)
But at least with a Diablo tuner you can data log for LT/ST Knock Retard to see if its a fuel issue and not the tuning.
If you're getting knock due to lower octane fuel, the PCM will retard your timing and it will feel sluggish.
2 Truck Minority? you have Got to be Kidding me?
and in almost 4 years have yet to see anyone post a 13 second time slip with a Bully Dog Tuner on a 4G Ram.
But dont take my word for it, go visit a few forums,
they all have a Performance Section with an Official Time Slip thread. Proof Required to make your claims.
If Bully Dog is so much better at performance, and so dominant, then where are the time slips?
Challenge issued!
You miss read That Quote. "Originally Posted by Asur Great info and very good to have, but it is still only a 2 truck minority to that of the quantity out there."
If you read it correctly it means that you and your buddies trucks with a diablo tuner on it are a minority to the trucks out there in existence, meaning that the diablo tuner on other trucks with other computers with other mods may act differently than yours, other things like sea level, fuel etc can make differences. I did say your information was good information but its not the consensus of the majority of members experience with the product. But I see it is pointless to have a normal conversation in a forum with you, every time someone brings up a point about something and it does not jive with your thinking process you try to bash them. Its unfortunate for other members who happen to be reading these threads to have to read your offensive comebacks, Stuff like
"Originally Posted by BlackRamHemi
4.7L guys dont have freakin CLUE so you can dismiss their B.S. RFN"
your statement was definitely intelligent and well thought. That being said, I would not want to know what your thoughts are of a 3.6L guy.
Yes, I know, you will come back with a post of "get the number" , "I have placed a Challenge" , " Read the forums, your all BS" Well sorry for pissing in your cornflakes but posting crap like that will not make you sound any smarter. Sorry you feel you need to bash people.
the thoughts and information expressed in this post are that of the posting member and not that of the Forum, please kindly use it as such.
Old 09-16-2013, 07:00 PM
Grubrunner's Avatar
Rep:3883
Almost all members list their gear in their sig lines...Now YOU tell me which tuner is in the Minority. 2 truck minority pfffft!!
In all seriousness, and bashing aside, just because you haven't seen it first hand - weather it be on the various boards you frequent or up close and personal - it doesn't mean it does not exist. True?
Let's call a spade what it is: the 4.7L owners' contribution on this thread have been based on their personal experience; just like your contributions have been the same. No point bashing a guy for his opinion based on his personal experiences, right?
Otherwise, if the shoe fits.....
To label all 4.7L owners as being full of shit and having no clue is, we'll, not only uncalled for but just downright tasteless and extraneous.
Cheers.
Grub out!
Old 09-16-2013, 08:30 PM
BlueJet BlueJet is offline
Vehicle: Blue
Rep:3934
Keep it civil gentlemen or this gets shut down. Thanks.
