Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel
Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Old 09-10-2013, 02:57 PM
BigRey954 BigRey954 is offline
Vehicle: 2012 Ram 2500 4x4
BigRey954 is on a distinguished road
Default 2012 Ram 2500 over heating with the H&S on
I have a 2012 ram 2500 lifted on 37's. I installed the H&S mini max, DPF delete, and did an intake. Ran great for a few months and just the other day it started overheating. The programmer then says defueling and deprograms itself to stock mode when reaching the high temp. Anyone hear of this happening? I don't know what to do. Please help
Old 09-10-2013, 04:23 PM
NWRQC's Avatar
NWRQC NWRQC is offline
Vehicle: 2007 RAM
Rep:64
How hot is it getting?
What is your hot coolant defuel set at?
What tune are you running?
It could possibly be a blown HG.
What other mods do you have done?
2007 6.7 | EFI-Live | Draconian tuned TCM | T4 S366 | ARP | AFE | Thuren | Carli
Old 09-10-2013, 05:30 PM
when I noticed it I saw it at 230 and it was climbing. Those are the only mods I have done. I dont know if it is a blown head gasket because it runs at normal temp when the programmer is on the stock setting.
Old 09-10-2013, 05:40 PM
Any other setting than stock it starts to over heat
Old 09-10-2013, 05:45 PM
And when it does over heat on the other settings its whole I'm babying it aswell
Old 09-10-2013, 07:57 PM
NWRQC's Avatar
Vehicle: 2007 RAM
Rep:64
Your dash gauge corresponds with what the display on the MM is reading?
Old 09-11-2013, 12:23 AM
Yea it does read the same
Old 09-13-2013, 06:49 PM
NWRQC's Avatar
Vehicle: 2007 RAM
Rep:64
What tuning are you running (tune version and firmware version).
Old 09-15-2013, 03:57 PM
BrandonMski's Avatar
BrandonMski BrandonMski is offline
Vehicle: 2006 Dodge Ram 3500
Rep:24
BrandonMski is on a distinguished road
I'm no expert but it sounds like to much fuel and not enough air. Raising boost pressure, a proper exhaust, and intake might help quite a bit. Check with Bully's Performance. Eric gave me a fantastic price on an Fass 95 about a week ago.
2000 Dodge Ram 1500 Sport 4x4 - 5" lift, 36" tires, CIA, exhaust, CB radio, bed liner, undercoated, and more
2006 Dodge Ram 3500 Laramie 4x4 - trans temp, EGT, boost gauges, 5" exhaust, CIA, Fass 95GPH
Old 09-15-2013, 06:54 PM
NWRQC's Avatar
Vehicle: 2007 RAM
Rep:64
Unfortunately an aftermarket intake won't get more air into his engine, the OEM set-up is more than efficient, but he already has an aftermarket intake.
Raising boost won't do anything as that's simply a measurement of restriction..
But you did give me a thought. He said he has a DPF delete. Is that just the DPF gone but the NOX and Cat are still present? If so, OP are you running DPF delete tuning with the other components in place?
