Old 09-10-2013, 03:20 PM
Pantherjoe Pantherjoe is offline
Vehicle: 2013 1500 Ram
Trim Level: Big Horn CC
Color: Cherry red
Pantherjoe is on a distinguished road
Default Alarm
When I lock the truck using the key fob then come back later and unlock it using the "hidden key" in the key fob, it sets off the alarm. Is this normal and if so what could the reasoning be for it?
NewRamer
Old 09-10-2013, 03:32 PM
toober's Avatar
toober toober is offline
Trim Level: Tradesman
Rep:26
toober is on a distinguished road
Did you check the owners manual, page 21?
http://www.ramtrucks.com/en/owners/manuals/
Old 09-11-2013, 04:46 AM
texasmedic's Avatar
texasmedic texasmedic is offline
Vehicle: 2013 RAM 1500 4X4
Color: SILVER
Rep:78
texasmedic will become famous soon enough
yes its normal the reason is if you use the key to unlock it you are not turning the alarm off. Why are you using the hidden key to unlock it Its more for is the door locks malfunction not for everyday use.
---Veraram---87mm PTB---2" leveling kit---3" PA Body Lift---Iron Cross Push Bumper--- 34 Inch LED Light bar---35x12.5 R18 Atturo Trail Blades---18" Black Ballistic Morax wheels---CB radio---Bullydog Tuner---Dash mounted GPS---
Old 09-11-2013, 06:46 PM
Color: Cherry red
I was just horsing around getting familiar with everything.
NewRamer
Old 09-11-2013, 06:51 PM
Color: Cherry red
Yes I did, but it came no were near explaining the reason. It just said how to activate the alarm. It kind of gave me the impression that locking the truck with the key fob and not using the lock button on the door, that the alarm would not be activated.
I do wish it had a more obvious alarm active light so it could be easily seen by passer bys.
NewRamer
Old 09-11-2013, 08:21 PM
Thunderhorse's Avatar
The Sound of Eight Hooves
Rep:545
Thunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of light
I'd say its abnormal because my truck's alarm doesn't trip when I use the hard key to unlock it.
Thunderhorse-Built: 25 Feb 2013 Warren, Michigan; Bought: 28 May 2013
Huskyliner Weatherbeaters, door edge guards, Line-X bedliner, Kryptek Typhon Cordura seat covers w/ MOLLE panels (review), Console Vault (install/review), Bilstein 4600s (thread), BFG T/A KO2 LT275/60/20s (thread), Borla XR-1 (thread), Matte black Plasti-dipped center console bezel, BT catch can.
Old 09-12-2013, 01:41 AM
CharlieL CharlieL is offline
Vehicle: 2013 Ram 4x4 Crew Cab
Rep:100
CharlieL will become famous soon enoughCharlieL will become famous soon enough
Are you sure your truck's alarm is actually setting? Mine didn't when first purchased & I had to get the dealer to take some action to turn it on. Easy check - lock the truck with the window down. Leave the fob elsewhere, reach in and open the door. You will then know without a doubt if the alarm is arming or not...
Old 09-12-2013, 12:15 PM
Explorer Rob's Avatar
Explorer Rob Explorer Rob is offline
Vehicle: 2013 Ram 1500 4x4
Trim Level: Laramie Longhorn
Color: Black Gold / White Gold
Rep:264
Explorer Rob is a jewel in the roughExplorer Rob is a jewel in the roughExplorer Rob is a jewel in the rough
Maybe it is only the push button start that sets off the alarm with the key? My alarm sounds when I use my hidden key. Probably not an issue with the regular remote keyless entry since the key has the chip in it.
