Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - General Discussion > 2014 Dodge Ram Forum
2014 Dodge Ram Forum For specific discussion of the 2014 Dodge Ram!
Old 09-10-2013, 05:27 PM
skytop's Avatar
skytop skytop is offline
Vehicle: 2014 Dodge Ram
Rep:420
skytop is just really niceskytop is just really niceskytop is just really niceskytop is just really niceskytop is just really nice
Default Saved over $4,699. on brakes today
Ready for your eyes to pop? A Brembo big brake kit (#1J1.9002A2) which is for calipers, pads and drilled rotors for the front only cost $4,699. And that is the discount price. Wilwood is about the same.
I needed a brake upgrade on all 4 brakes so you can do the math to see what Brembo would cost. Since I work for a living and never hit the lottery or got a federal gov't job, I could not go that route. Instead, I went with PowerStop drilled ventilated rotors with matching hi performance pads. To get the "look" of the "high price binders," I stopped at AutoZone and picked up a high quality brake caliper paint kit (cleaner prep and caliper paint w/ brush) in OEM red (same color Dodge uses on SRT calipers).
So instead of polishing and powder coating, I cleaned and painted the stock calipers and they look great dressed up in red and costing little to do.
It took exactly an hour to change over all four brake assemblies and paint the calipers. I have attached a photo of the installed front brake showing the entire assembly. There is also a pic with the wheel mounted. Ah....the pleasure of doing a good job, doing it yourself and saving a pile of cash to boot! BTW, I loved seeing the trick Ram alloy suspension members. Lots less weight for a more compliant suspension!
Old 09-10-2013, 05:29 PM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
That looks awesome. Good way to save thousands of dollars!
Old 09-10-2013, 06:10 PM
2014LHLTD's Avatar
2014LHLTD 2014LHLTD is offline
Vehicle: 2014 Ram Limited TrueBlue
Trim Level: Limited
Color: True Blue
2014LHLTD is on a distinguished road
Great little mod! Thanks for sharing and its certainly a way to save almost 5K!
Old 09-10-2013, 06:47 PM
Rusty289's Avatar
Rusty289 Rusty289 is offline
Vehicle: 2014 Ram 1500 Crew Cab
Rep:117
Rusty289 will become famous soon enoughRusty289 will become famous soon enough
Looks really cool, mind if I steal your idea for mine?
Really cleans up the look, hot rod like.
If ya can't Dodge it, Ram it!!!
Old 09-10-2013, 06:53 PM
Grubrunner's Avatar
Rep:3883
That's a typo, right.
No chance it too 1HR to paint all four brake calipers and install complete new assemblies all round.....
Grub out!
Old 09-10-2013, 07:53 PM
astonius astonius is offline
Trim Level: Laramie Limited 6'4"
Rep:30
astonius is on a distinguished road
Looks nice! How's the performance compared to stock rotors?
Old 09-10-2013, 09:37 PM
skytop's Avatar
Rep:420
Cool
No typo. By the clock, I rented space on a front end machine not being used at the time at a friend's shop. With the truck being brand new, every bolt came out without the slightest problem. No rust, no problems. The lift was a huge time saver allowing eye level work. Also, painting the calipers at eye level was a big convenience. Each caliper took only about 5-6 minutes and was painted after the rotors and pads were changed over. I could have done an even "neater" job if I had more time to paint the calipers off the truck but I did not split the brake line and painted the calipers 'on the spot.' I am a long time hot rod builder and love doing these kinds of mods. Before I did this job, I checked out an SRT Challenger to see how the Dodge boyz did their brakes. This is not as sanitary and smooth as Brembo, SSBC, AP, Wilwood or Dodge since the calipers are not polished out. The raw Ram caliper castings works well with the paint and when painted offers plenty of "eye candy." This is not show car level work but for a working truck, it is a great inexpensive trick upgrade that offers improved braking and an improved level of 'cool' for the street.
Old 09-10-2013, 09:46 PM
country-boy country-boy is offline
Vehicle: 2014 Ram
Rep:87
country-boy will become famous soon enough
You painted the calipers on the truck??
Old 09-10-2013, 10:39 PM
Chunkem's Avatar
Chunkem Chunkem is offline
"Just living the dream"
Trim Level: Longhorn Rambox
Rep:1637
That looks sweet.....Nicely done.....
Grubrunner's Avatar
Rep:3883
So the calipers were left in place and just hit directly with a spray can? Single coat only?
No priming, no clear coat, no multiple coats, etc...?
Okay....
Grub out!
