Old 09-10-2013, 07:34 PM
dirtydiesel51 dirtydiesel51 is offline
Vehicle: 2000 Dodge Ram
Engine: 1999-2000 359ci (5.9L) Cummins ISB 24-Valve Diesel I6 235hp 460lb/ft (manual)
dirtydiesel51 is on a distinguished road
Question Tire width
Hello, I have a 2000 Dodge Ram 2500 5.9 Cummins. I have a 2.5 inch body lift with a 3" suspension lift and I am planning on getting a 4.5" suspension lift. I have 35x12.5 r17 tires on it now. COuld i fit 13.5 inch wide tires with the 7" total lift?
Old 09-11-2013, 07:54 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
Not terribly familiar with 2nd gens, esp the 2500s. But i dont see why you wouldnt be able to clear that. It's not that much wider, and a few 35s run wide at 13.5" anyway and people fit those on 1500s with just a level and some spacers/offset wheel.
Old 09-11-2013, 03:51 PM
Thanks, what offset would i need? would i need spacers? Im new to getting new tires
Old 09-11-2013, 04:08 PM
Rep:1900
are you getting new wheels?
if so, I'd go with a -12mm or -24mm offset wheel. depending on the width of the rim. if you aren't getting new wheels and running stock wheels...you might need spacers. I am not sure
Old 09-12-2013, 09:08 PM
i am getting new wheels. Tell me if you think these are good.
Thanks for your help
http://www.ebay.com/itm/20x9-Black-F...44d0e8&vxp=mtr
