How low can I go - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 01-12-2014, 12:59 PM
shostopper17's Avatar
shostopper17 shostopper17 is offline
Vehicle: 2011 Dodge Ram Express
Trim Level: 1500 Express
Rep:54
shostopper17 will become famous soon enough
Default How low can I go
So for my 2011 express RCSB 4x4 how low can I go??? and what is the best kit/ air ride
Old 01-12-2014, 01:11 PM
shawnu's Avatar
shawnu shawnu is offline
Vehicle: 2012 Ram
Rep:517
The lowest kits available are 2/4, belltech and McG, spindles would be best but also widen your front track by 1/2 or so.
To go lower in the back you can cut the spring for 5in and you can double springs and spindles up front for 4in. But going lower in the rear you would have to relocate the control arms, i have a time or 2, bottomed out and the lower touched the upper. Only on big dips goin 60 or so.
A little more into rear lowering than leaf spring trucks... thats why ive been bouncing around the idea of slamming my 98 silverado. Lol. 5/7 is what id like.
12 Flame Red RCSB Express- Sold 3/2015
17 Blue Streak R/T Ordered 5/23/2017
Delivered 6/22/17
Old 01-12-2014, 01:25 PM
Rep:54
sounds like a plan once April hits and snows gone then the drop will be on and back with my 22's
Old 01-12-2014, 02:19 PM
Rep:3347
You will have headaches lowering a 4wd. Mine is down 4/6 using the McG's spindles and GF springs up front and the 2wd rear McG's spring kit with Belltech sports shocks. I'm swapping the rear springs out for the Hellwig air spring kit so I can have more control over the rear height and if I ever need to tow I can. I'm also running the Michigan Metal Works front upper control arms to try and bring my camber closer to spec, but I would recommend a set of adjustables from Mike at L&M. I'm running the rear Spohn adjustable control arms with their adjustable panhard bar as well. You need to completely remove the rear bump stops if you want to go this low, and you'll have about 1.5" clearance from the axle to the frame. "Luckily" you'll hit the frame before you bind the rear control arms.
Old 01-12-2014, 02:20 PM
shawnu's Avatar
Vehicle: 2012 Ram
Rep:517
Wait, i seen your 4x4...im not sure on the kits for them.. i know i have seen them lowered though!!
Edit: He beat me to it^^ lol
Delivered 6/22/17
Old 01-12-2014, 04:46 PM
Rep:54
Im, thinking my option is going to be the groundforce 2/3 drop
Old 01-12-2014, 07:06 PM
Rep:3347
If you just want bolt-on then the GF kit is the way to go. If you want to go lower you can cut the springs or start playing mix and match. I would recommend the adjustable panhard bar or the Belltech relocation bracket to recenter the axle whatever way you go.
Old 01-13-2014, 05:00 PM
mikennrg mikennrg is offline
Vehicle: 2012 RCSB Express
Rep:97
mikennrg will become famous soon enough
If you go lower than 4'' in the rear you really should get the Spohn adjustable control arms.
Old 01-13-2014, 09:45 PM
Rep:97
The spindles widen that much if you don't lower it further like the OP wants to due. Lowering it another two inches will tuck the wheels in further due to front suspension geometry.
Old 01-13-2014, 10:12 PM
Rep:3347
It also kicks your camber out of spec, and they are still wider than the fenders with the 4x4s. Mine are sticking out from under the fender 3/4" with a 4/6 drop.
