Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 09-12-2013, 01:25 AM
mrlarry24 mrlarry24 is offline
mrlarry24 is on a distinguished road
Default '05 1500 4x4 with 4" lift. Tire Recommendations??
Hey guys...
I have a 4" suspension lift and 2" leveling kit in the front. (2005 Ram 1500 4x4)
I'm going to need new tires before winter and was wondering what people think I can fit under there.
I looked through 14 pages of the "Tire Size and Lift Guide" on this site, but didn't really answer the question as I didn't find the same set up.
I currently run 275 65R 20 with aftermarket wheels. I have no idea of the offset. What I do know is it looks like there is quite a bit more room to fit bigger tires.
I took my tape and measured 42" from ground to middle of fender.
I would like to get taller, but also a little wider and maybe some spacers as I want to get fender flares as well.
Obviously from this post, I'm not very technical, so I'm hoping someone could hep me out!
Thanks
Ram Air induction hood/4" Rancho suspension lift/Superchips/
Flowmaster dual 4" / 275 65 R20
Old 09-12-2013, 02:19 AM
brandonjansen's Avatar
brandonjansen brandonjansen is online now
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
It would be helpful if you could find out the width and offset of your rims. We'd have a lot more information to go by then. But you should be able to fit a 35x12.5 on there no problem. Just make sure you have an extra 1" or so on the inside of your current tire to the suspension.
