Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Electrical
Electrical 1st Gen Dodge Ram Electrical Problems and Questions.
Old 09-12-2013, 03:25 AM
GEN1's Avatar
GEN1 GEN1 is offline
Vehicle: 1993 Dodge W350 Dually Flatbed
Color: many, camo, black, red,
Engine: 1989-1993 360ci (5.9L) Cummins diesel I6 160hp 400lb/ft
GEN1 is on a distinguished road
Default Revers lights wiring diagram
Looking for info on what wires are used for the reverse lights on a 93 w350. The truck has been switched to a flatbed, and looks like the previous owner never hooked up any reverse lights. I found some purple wires in the rear light harness which look like they may be the ones for the reverse lights, but have no power to them. Anyone know where the signal for the lights to come on comes from?
Old 09-12-2013, 08:35 AM
crazzywolfie crazzywolfie is offline
Vehicle: 81 91 93 dodge
crazzywolfie is on a distinguished road
the purple wire should be the backup light wire. there will not be any power there unless you have the truck in running and in reverse.
91 & 81 d150 carburated 318's 93 R.C. F.I.318
Old 09-12-2013, 07:57 PM
GEN1's Avatar
shouldn't there be power to the wire if the ingnition is on and truck in reverse gear? Also, is there a ground in the wire harness, or does it just ground to the body?
Old 09-12-2013, 08:49 PM
ya there should be. you may want to check for power at the neutral safety switch. could have a bad neutral safety switch or a bad wire somewhere. the backup light shared a ground wire with the turn signals from the factory. you can ground them anywhere on the frame. my auxiliary backup lights on my trucks are grounded to the frame. just make sure you clean up the area that you are grounding them to good.
