Old 09-12-2013, 09:41 AM
SCRT SCRT is offline
Vehicle: 2011 Ram RT
Trim Level: RT
SCRT is on a distinguished road
Default 2011 RT Headlight Problems--HELP!!
I have a 2011 Ram 1500 RT with quad headlights. A couple of weeks ago my left side headlight stopped working, both high and low beam bulbs. Several days later they are working again. Last week the right side stopped working, again both high and low beam bulbs. I left it at the local Dodge dealer...truck still under warrenty. They said the left side low beam bulb was out and it was causing the problem. I'm not a electrican but would Dodge design a system that if one bulb went out it would effect the entire system. HELP. Thanks
Old 09-12-2013, 11:11 AM
Arth's Avatar
Arth Arth is offline
Color: Mineral Gray Metallic
Rep:2028
No they don't.
This has been popping up a lot recently and it has usually been because of a lose ground pin on the headlight connector.
You need to pull the headlight and check the connector. The black wire is the ground. Try pushing it back into the connector a bit.
If you lose the ground that is why your headlight loses low/high beam and still has parking lights. Parking lights power is on another connector.
Chrome... in moderation.
Old 09-17-2013, 01:26 PM
wfmoose3 wfmoose3 is offline
Vehicle: 2011 Dodge Ram 1500 Crew
wfmoose3 is on a distinguished road
Would this cause only the low beam to not work?
Old 09-17-2013, 01:54 PM
Arth's Avatar
Rep:2028
No.
If it was the high and low this would apply to you. If it is only one that is out then it should be a bad bulb.
Old 09-19-2013, 10:24 PM
LeftCoast's Avatar
LeftCoast LeftCoast is offline
Vehicle: 2012 Ram
Trim Level: Sport Crewcab
Color: True Blue Pearl
Rep:248
LeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura about
I had a similiar problem. Truck has been fine for over a year since I bought it, but a couple weeks a go the drivers side low beam works intermittently. Sometimes its on when the truck starts , sometimes its not.
Probably the only 2wd Blue Crew in Canada.
Mod list Debadged, Airlift 1000 airbags, Cabin Air Filter Mod
, BT Catch Can.
