Old 09-12-2013, 01:16 PM
arctic-rodz arctic-rodz is offline
Rep:53
arctic-rodz will become famous soon enough
Default 2013 Level, wheel option?
Will be leveling my truck pretty soon and had a question about wheels. Im probably going after market after my level. But i want to go with 305/55R20 Nitto Terra Grapplers. I know they are just a touch taller than the OEM tire size but the width should give it that nice stance.
I have a 20x9 with 0mm offset in mind but also a 20x10 with -14mm offset.
Would the 20x10 with -14mm offset be too much for a level only or should i stick with 20x9 0mm offset.
2013 RAM 1500 Sport 6speed Crew 4x4
Old 09-12-2013, 02:25 PM
Whiplash's Avatar
Whiplash Whiplash is offline
Vehicle: 2013 1500 SLT Big Horn 4x4
Color: Black Gold
Rep:177
Whiplash has a spectacular aura aboutWhiplash has a spectacular aura about
unless i'm mistaken and not learning what i think i am....20x10 @ -14 = 20x9 @ 0 in relation to the proximity to the truck
-14 will push the center of the rim out 1/2" which is your 14mm difference
MODS: Magnaflow 16869 cat-back - S&B CAI - BakFlipG2 - Bilstein 5100s F/B - AirLift 1000 - BackRack - FT-857D/ATAS-120
next: Rims 'n rubber - That'll be it, too many electrical risks involved to go furthur
Old 09-12-2013, 02:33 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
you should be fine with either choice. personally id go 20x10 w/ -14
Old 09-12-2013, 05:41 PM
Rep:53
i thought with the 20x10 i might have clearance issues when at full lock or when the suspension flexes.
not gonna be doing any major off roading but still.
Old 09-12-2013, 07:41 PM
Whiplash's Avatar
Color: Black Gold
Rep:177
if you're going to be using the exact same tire on either rim you'll be 1mm further out on the 20x10/-14 than you will with the 20x9/0. the question is are you planning to run too wide/tall a tire, and that i can't tell ya...haven't gotten that far at RamForumZ school yet
i do know that there is near 0 difference on the stance between those two rims
Old 09-13-2013, 12:31 AM
brandonjansen's Avatar
Trim Level: Laramie Limited
Rep:2051
If you're only running a 305/55/20 tire on the 20x10 -14 rim with a leveling kit you should be okay. But if you go to a bigger tire down the road you'll run in to rubbing problems.
A 20x10 -14 wheel with a 305 tire is going to be sticking out about 2" past your fender. A 20x9 0 offset with the 305 tire will stick out about 1" past your fender. Just in case you wanted to compare the difference between the two.
Old 09-13-2013, 11:19 PM
Rep:53
Yeah, thats kinda the idea i wanted to get. I figured the further the wheel sticks out, the closer it would get to the front/rear wheel well when i turn that would cause it to rub.
the 20x10 2" out of the fender would look good, but for the sake of keeping the paint in better shape i think the 20x9 with 1" out of the fender will do fine i think.
im not sure how i feel about mud flaps.
Old 09-15-2013, 07:09 PM
Rockyd831's Avatar
Rockyd831 Rockyd831 is offline
Vehicle: 2013 Dodge Ram 1500 Sport
Rep:33
Rockyd831 is on a distinguished road
Cant wait for some pics!!!!
2013 Ram 1500 CC - Silver Grey Metallic,2.5" Level,OEM Fender Flares
More to come.....
Old 09-15-2013, 07:55 PM
Whiplash's Avatar
Color: Black Gold
Rep:177
same, would really like to see how you make out with the 20x9/0s
Old 09-17-2013, 07:58 AM
Spike Spike is offline
Vehicle: 2013 RAM Big Horn 4x4
Rep:58
Spike will become famous soon enough
You can run that tire on your stock wheels, assuming you have the factory 20's anyway. I am with no spacer and no lift.
2.5" Lift, 305 R20's, Winch, Softtoper,
K&N, ZJ in tow, German Shepherd co-pilot
