Old 09-13-2013, 12:41 AM
ramowner99 ramowner99 is offline
Vehicle: 1999 dodge ram
ramowner99 is on a distinguished road
Default fuel gauge wont work!
Hi have a 1999 dodge ram 2500 5.9 gas. I've replaced sending unit and have checked all wires and fuses and relays. Gas gauge stays on empty but when I clear check engine light it goes to full for about 30 seconds then drops back to empty! What could be wrong with it?
Old 09-13-2013, 01:10 AM
richmond richmond is offline
Vehicle: 1999 Dodge Ram
Rep:177
richmond has a spectacular aura aboutrichmond has a spectacular aura about
Fuel sending unit is defective or pop the tank with a rubber hammer. My 98 1500 5.9 farm truck is out, rather than pull the bed and replace it, I use the trip meter at each fill-up on the odometer. If I'm mostly town driving it's 10 mpg on the 26 gallon tank. If it's interstate I'm 15 mpg on a the same 26 gallons. So 200 miles and fill for the first scenario and 300 miles and fill for the second scenario, reset at each fill up. Many of our guys would fix it now. The HEMI I would and like wise the diesel (the old 5.9 1500 is a local farm truck though). R...
Old 09-13-2013, 07:40 AM
primo spaghetti's Avatar
Vehicle: 2014 Ram Sport
Color: Maximum Steel Metallic
Rep:910
where was the sending unit that you changed? in my 96 i was told it was on the pump and i would have to replace the pump to change the sending unit, so i too used the trip meter to guage my gas consumption....
i also read that the oil pressure sending unit could adversely affect the fuel guage if it was shot. i cant recall where i read it but it was a dodge forum.
