Old 09-08-2013, 10:36 PM
GtEcH25's Avatar
GtEcH25 GtEcH25 is offline
Trim Level: BigHorn
Color: True Blue
GtEcH25 is on a distinguished road
Default Spintech Super Pro Street's
I have 2 Spintech Super Pro Streets laying around at home. I would like to attempt to put them on. My question is should I use both of them or just one? I would just be removing the muffler and have an exhaust shop either taking one muffler and splitting it at the outlet or splitting from the stock inlet into each muffler. Any recommendations? Thanks.
Matt
Old 09-08-2013, 10:50 PM
shawnu's Avatar
shawnu shawnu is offline
Vehicle: 2012 Ram
Rep:517
Personally if your your going to replace that horrible y pipe, id use both in a true dual set ip with an x pipe since you already have 2.
If not, id install one with a y pipe after it, you can get a magnaflow y pipe on amazon thats great quality for ~$25. You wont see a huge gain doing true duals, but it will be noticeable as some have said, mostly from removing the restrictive oem y pipe.
I havent heard much about the spin techs here, over on GMFULLSIZE it was very popular like maggies are here.
Good luck with the install, let us hear a clip when you get r done!!
New audio build in progress
Old 09-09-2013, 10:12 PM
GtEcH25's Avatar
Trim Level: BigHorn
Color: True Blue
Good deal. Thanks for the advice. Problem is finding a reputable shop around here that does good exhaust work. I'd like to go true duals with an x or h pipe. Anybody know what the stock exhaust size is? The mufflers I have are 2.5 inlet/outlet so I'm hoping they'll fit.
Old 09-09-2013, 11:33 PM
Gecko's Avatar
Gecko Gecko is offline
Vehicle: 2004 Quad Cab
Trim Level: SLT 4x4
Rep:221
Gecko has a spectacular aura aboutGecko has a spectacular aura aboutGecko has a spectacular aura about
I think the stock exhaust is either 2.25" or 2.5". Either way, if you find a good shop they wont have a problem making it fit. They will have pieces that will go from 2.25" to 2.5" so that the mufflers fit without a problem.
Supercharged, cammed, other things too!
Old 09-10-2013, 05:22 PM
GtEcH25's Avatar
Trim Level: BigHorn
Color: True Blue
Ok. Good. I was hoping it was around 2.5". That makes it easier. I'm worried its going too loud and obnoxious. I'm not looking for the cackling sound and the back pressure popping. If I have either of those I'll end up removing them and putting on an 18" Magnaflow or Flowmaster.
Old 09-11-2013, 12:47 AM
Gecko's Avatar
Trim Level: SLT 4x4
Rep:221
If its making those noises than you'll probably want the Magnaflow. Its a much smoother deeper sound than the Flowmasters. I had the Flowmasters and I'm glad I switched to the Magnaflows.
Old 09-11-2013, 08:45 PM
shawnu's Avatar
Vehicle: 2012 Ram
Rep:517
Factory exhaust is 3" inlet and 2.25" outlet. But any decent shop eill have adapters to make them fit.
I heard nothing but good things about spintech on the gm forums, the prostreets are the loudest muffler they make isnt it?? I bet its going to sound beast!!!
