Old 09-14-2013, 09:41 AM
Fasthemiram11's Avatar
Fasthemiram11 Fasthemiram11 is offline
Vehicle: 2012 Ram Express
Rep:15
Fasthemiram11 is on a distinguished road
Default Off The Grid...
Been lurking in the background for some time now and thought I'd update everyone on the parts I've acquired...
Ripp Supercharger kit
6.1 Intake Manifold
BBK Fuel Rails
Arrington 90mm TB
Kooks Longtubes
FTC Converter
392 Cam
392 Crank
Water meth parts
392 Ring and Pinion
Black Catch Can
3" 4" Drop Parts
phat shot N2O solenoids
AEM fuel pump
Stock set of wheels to narrow and widen.
Deep Trans Pan
Sharadon vb
2010 PCM swap
Spare Trans to build
Still need to get
forged rods and pistons
392 Heads
LSD carrier
Slicks
More N2O parts
ARP Main and Head Studs
2012 SOUTHERN EXPRESS
Had 2011 HEMI EXPRESS 12.4@111
Old 09-14-2013, 11:06 AM
shawnu's Avatar
shawnu shawnu is offline
Vehicle: 2012 Ram
Rep:517
Now thats a list!!! Whats your goal for the 1/4??
New audio build in progress
Old 09-14-2013, 03:57 PM
HemiLonestar's Avatar
Rep:261
Are you using your stock 5.7 block? I heard somewhere that Apache heads won't bolt to a 5.7 block.
"Big Red"
2006 Charger R/T
Old 09-14-2013, 05:18 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
I read on a Chally forum that you have to bore notch the block otherwise the valves hit.
nice list of parts! I'll share my list in a month or so when we are done deciding.
Old 09-14-2013, 05:28 PM
CHVYKLR's Avatar
Rep:252
here are 2 quotes from a guy that has already installed the apache heads on a 5.7. he did a before and after dyno comparing ported eagle heads to ported apaches and gained 44rwhp.
"both sets were ported. They will fit a 5.7 block, but you need to bore notch the block to be safe."
"With the heads you will need 6.4 valve covers and a custom length pushrod. Everything else including the manifold swaps over no problem. The camshaft has to be limited to a 218/224 grind as the intake valve sits closer to the piston limiting our ability to run the larger camshafts. I cant say with 100% certainty what the gains would be on a stock block, but I expect them to be about 30rwhp better than a ported 6.1 head with the same camshaft."
Old 09-17-2013, 10:32 PM
Rep:15
If I have to notch the block Apaches wont be going on... ill just do some Thiteks!!
Old 09-17-2013, 10:35 PM
Rep:15
11's or bust...
Old 09-19-2013, 11:37 AM
shawnu's Avatar
Vehicle: 2012 Ram
Rep:517
Hell yeah!! Glad to see someone doing a good motor buidl!! Not that a s/c is bad or anything. Just something different!!
Keep us updated!!
Edit: i didnt see the first mod....a Ripp kit. Lol.
Still a damn good list id never get collected!!!
