Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Interior and Exterior Lighting
Place your Ad Here!
Old 09-24-2013, 09:57 PM
Stump3r's Avatar
Stump3r Stump3r is offline
Rep:1276
Are you running anti-flicker modules? If not that is your problem right there. On my 11 Ram there was only a canbus loop on the headlights, fogs would fire no problem. Now with the 13 all lights are on the feedback loop. When I first threw on the HID's my fogs would not fire, I checked everything and was left scratching my head. Luckily I had one fog that would flicker 3 times then go out, pulled one of my anti flicker modules off my low beam and threw it on the fog...boom everything worked. Now if you have canbus ballasts well then you may have a low voltage issue. My lows and fogs are done with Beamer kits, one set canbus one set standard and they fire without issue off of the factory harness.
Big Red my old 2011 Sport
Old 09-24-2013, 10:41 PM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
Originally Posted by DatacomGuy View Post
So you needed a wiring harness for the fogs too?
Yes, I needed only a wiring harness for the 35 watt fog lights from DDM Tuning. That was all that was needed, no anti-flicker modules, no canbus ballasts, or any resistors.
Greg
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
