Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2013 Dodge Ram Forum
Place your Ad Here!
Old 09-14-2013, 10:25 AM
morninton morninton is offline
Vehicle: 2013 ram sport
Trim Level: sport
Color: cherry
morninton is on a distinguished road
Default air conditioning 2013 sport
The ac in my new truck (had it less than 2 months) is not
cooling correctly. Have to turn it down to 62 degrees or less to
get max cooling. Even then it fluctuates with cool to almost warm air.
Anyone have similar?
Old 09-14-2013, 11:57 AM
JCC11 JCC11 is offline
Vehicle: 2013 RAM & 2014 RAM (ordered)
Trim Level: Laramie Limited(s)
Rep:20
JCC11 is on a distinguished road
That is exactly the way it is meant to work. If you are like me and want nothing but cold air blowing at all times in warm weather, you set temperature to the lowest setting ("LO") and adjust fan speed as needed.
Any temp setting above "LO" cycles the compressor on and off as needed to keep your set temp. This makes the air feel like a mix of cool and warm air, as you mentioned. Setting temp even one degree above LO will cause this to happen. That may be ok when the outside temp is 58degF, but not when its 88degF. I want icicles! Set it to LO and you will get just that.
Also, once you set it to LO, press the "Sync" button (if you have the 8.4 radio) to ensure both driver's side and passenger side are set to the coldest setting.
Old 09-14-2013, 01:02 PM
Trim Level: sport
Color: cherry
thanks immensely...I'll give it a try
Old 09-14-2013, 01:24 PM
cjgerson's Avatar
cjgerson cjgerson is offline
Vehicle: 2013 RAM 1500
Color: Black Clear Coat
Rep:65
cjgerson will become famous soon enough
Yes low and auto seems to be the setting i like when its above 80.
RetraxOne Tonneau cover, DeeZee tailgate assist, Line-X premium bed liner, Bed Rug Bed Mat, Freedom Tailgate seal, Cabin Air filter, aFe Magnum FORCE Air Intake System, Muffllex DOD18M, AVS Aeroskin Hood Shield, Craven Stubby Antenna, Tinted Windows, AVS In-Channel Vent-visors, AMP Research Black Bed Xtender HD, Hypertech Interceptor, E&G Classics - Polished Heavy Mesh Bumper Grille insert , Lamin-X 3rd brake and fog lights, E&G Classics Polished Heavy Mesh Bumper Grille Insert
Old 09-14-2013, 07:40 PM
Explorer Rob's Avatar
Explorer Rob Explorer Rob is offline
Vehicle: 2013 Ram 1500 4x4
Trim Level: Laramie Longhorn
Color: Black Gold / White Gold
Rep:311
Explorer Rob is a jewel in the roughExplorer Rob is a jewel in the roughExplorer Rob is a jewel in the roughExplorer Rob is a jewel in the rough
Wow, I just keep mine on fresh air and set to 72 degrees. I haven't had a problem staying comfortable with outside temperatures up to 115F.
Old 09-15-2013, 02:25 PM
Rep:20
Originally Posted by JCC11 View Post
I want icicles!
Rob, like I said......ICICLES! I don't want comfort; I want ICICLES! (temp set to LO, ventilated seat on high)
