Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Electrical
ZDOG
Old 09-14-2013, 03:39 PM
phantombullet phantombullet is offline
Vehicle: 2003 Ram 1500 Quad Cab 4X4
Color: Charcol Grey
phantombullet is on a distinguished road
Default Truck Problem
Don't know where to put this so I'm gonna put it here and hopefully somebody out there can help!
I have a 2003 1500 Quad Cab 4x4 SLT 4.7. My problem is this:
I have no right turn signal, no 1st intermediate wiper blade function, high beam switch shoots washer fluid instead of high beams, washer push on side of switch doesn't do anything, headlights go out after anywhere from 5 to 10 miles, move headlight switch to "parking light position" to have headlights, 4 ways, won't turn off even after you unplug switch. (Left turn indicator works fine)
So far, I have changed 2 turn signal switches, one from Autozone and one from a Dodge dealer. Both work for about 5 minutes and then things go haywire! I just changed the Multifunction Chassis Control Module/Relay that sits on the side of the fuse box. After all this took the truck for a drive and 5 miles down the road everything went to you know where! I am on a limited budget so the dealer is out.....I had one guy hook up his $8000.00 Snap On code reader and it says open faults R/S light system. Also, I checked all bulbs, grounds from front to back!
If anybody can help me out, this Disabled Veteran will THANK YOU ALL VERY MUCH!!!
Thanks,
Bobby
Old 09-14-2013, 07:49 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:446
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
Don't know, but it might be worth having the dealer diagnose, then you buy the parts and do it yourself. My dealer is very good at finding the problem, they have to give you an estimate on the parts and labor. The thing is, they have seen this before and know what the fix is. BTW, thanks for your service from another DAV.
Inertia Spartan + cam, Circle D 3,000 stall ,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's, Helwig rear sway bar,3:92's, extra rear leaf,Line-X Bedliner,GY Armortracs, 235,000 miles To Hell and back. 14.2/96 mph NEDW
Old 09-14-2013, 09:03 PM
Color: Charcol Grey
Thxs, I think this is my next option I'm gonna do! And BTW Thank You for your service also!
Old 09-19-2013, 10:15 AM
wchnu's Avatar
wchnu wchnu is offline
Vehicle: 2003 Dodge Ram
Color: red/grey
Rep:26
wchnu is on a distinguished road
What is the chance it is the switch on the steering column? The wipers and lights all are operated from there. Just a redneck guess.
"The very atmosphere of firearms anywhere and everywhere restrains evil interference - they deserve a place of honor with all that's good.
George Washington
Old 09-19-2013, 01:19 PM
Color: Charcol Grey
Changed that switch twice and it wasn't the problem!
Old 09-21-2013, 11:35 PM
mb power wagon's Avatar
mb power wagon mb power wagon is offline
Vehicle: 2007 dodge power wagon
Trim Level: power wagon
Rep:68
mb power wagon will become famous soon enough
it sounds like a short in the wiring system somewhere. i'd check the harness and the grounds
